help car struggles to start
Old Mar 25, 2008 | 07:08 PM
chevcamaro's Avatar
Default help car struggles to start
so i got a 94 camaro z28 last year and ran great all last summer. Then I parked it last winter and now it struggles to start. I have just changed plugs and wires and oil but i get same result. It cranks over but doesnt start in the mornings then I pump the gas a couple of times then when it feels like it it starts. By the way the check engine light does not come on some body please help me
Old Mar 25, 2008 | 09:57 PM
emj2006's Avatar
How many miles does it got?? It may be the good ol opti..
Old Mar 25, 2008 | 10:19 PM
Green3spd's Avatar
Lets not jump to the opit just yet...
How does it run once it's started? Does it shift and run ok at WOT? Miles?
Old Mar 25, 2008 | 11:38 PM
chevcamaro's Avatar
the car has 128,000 miles once the car has started it runs great and all day it starts and runs fine. Its just in the morning when it dosent want to start
Old Mar 26, 2008 | 12:06 AM
sweet-94z28's Avatar
Sounds like you may have injectors bleeding down and filling the cylinders with fuel. Basically flooding it.
Old Mar 26, 2008 | 07:50 AM
Green3spd's Avatar
could be injectors... I've never seen that happen, but definetely dont rule it out just yet. Let me ask you another question. When I doesnt start, is it wet outside? Or high Humidity?
The car I just bought, they guy had to replace the opti because of no-start when wet...
Old Mar 26, 2008 | 08:15 AM
LM97Z's Avatar
I'll be following this thread, as mine kindof has the same poblem, but according to the last owner, its been doing it for the last 6yrs. that he has owned it.
Whats an opti ?
Old Mar 26, 2008 | 08:41 AM
Green3spd's Avatar
Whats an opti ?
Huh...
Old Mar 26, 2008 | 10:51 AM
LM97Z's Avatar
This statement
Old Mar 26, 2008 | 12:09 PM
chevcamaro's Avatar
no when i start the car last couple of days it has been about 45 and dry
do you think a fuel inection cleaner could help or no ?
thanks for the help guys i really appreciate any advise thanks
Old Mar 26, 2008 | 03:56 PM
chevcamaro's Avatar
i talked to a vette mechanic and he told me that I should turn the key but not crank it and on the fuel rail push the valve in then have someone try to start it then push the valve again he said if I dont have a spray then the fuel pump is going bad.
I will try today and see also I read in another post that if I unplugg the battery all time like I have been doing that the computer has to learn to run again wtf
anybody heard of this before
Old Mar 26, 2008 | 05:37 PM
candela's Avatar
If you suspect the fuel pump, put a pressure gauge on the FPR. what you explained seems to be 50 times more complicated than a pressure gauge atached to the schrader (sp?) valve.
When the battery is dosconnected the computer has to relearn the idle. In my case, for the first few mins of reconnectimg the battery, my idle climbs as high as 1500rpms.
I currently am experiencing the slow/no start issue as well. I have a '95 formula and have not started to chase the culprit. Don't have the time or energy tackle this job again, repriming the fuel pump or tapping on the gas seems to get it going in the morning for me.
I used to have a 3.8 camaro before this formula, that had the same problem. It was the fuel pump in that instance. I have put a gauge on my formula and it iis holding proper pressure. The car has had a fulll tune-up including an opti replacement.
Old Mar 26, 2008 | 05:44 PM
94sleeperZ's Avatar
Please help i have somewhat of the same problem, mine starts right up but when getting on it, it backfires bad then when i shut it off i have the same problem? Hey sweet did you ever figure out the problem?
Cody
