Gasket Kit?
Don't go and get raped by summit.
You think summit is a rip? I'm totaly out of the loop as far as competitive parts priceing. Where I live either you order parts or you order other parts. Where do you get your parts from?
http://store.summitracing.com/partde...3&autoview=sku
Here is the front cover kit for a 95-96. It runs for $18.
http://store.summitracing.com/partde...6&autoview=sku
No Oil pan gasket
http://www.partsamerica.com/productd...tNumber=CS9966
http://www.partsamerica.com/productd...umber=TCS45956
http://www.partsamerica.com/productd...Number=MS95580
The felpro head gaskets are too thick unless the block is zero decked then they are OK.
I would sooner recommend Victo Rienz 5898 head gaskets at .026 for most builds with the piston at least .010 down which stock is way more. NAPA used to carry them but I think CarQuest is now the distributor.
Stock head gasket is .049 for the aluminum head cars, .029 for the iron head LT1s(another alternative), like I said Felpro are thick .039 only reason to run one that thick would be zero decked or even a LITTLE out of the hole with the piston.
I did not look up any valvecover gaskets because I have never replaced them, stockers are awesome.
Don't get me wrong Felpro is a good gasket, just their head gasket is thicker than what most of us should be looking at to up compression.
