Lt1 huge problem when warmed up
Old Apr 9, 2008 | 03:28 PM
caldercay's Avatar
Originally Posted by 93lt1n00b
OK first off this is a 1993 firebird formula the only mods are magnaflow catback and eBay CAI. the problem is when the car fully warms up at around 180ish the car will run like crap and sputter and surge. it never did this befor untill i instaled my CAI i just replaced the opti. new fuel pump new wires and plugs. on first cold start up the car will run fine. this only happens when it is warmed up can somone please help me out here
Can you put back to OE air intake and see how it runs? That's what I would do. So,
if it runs fine that way, then pay attention to ALL connections to the air intake and
be sure to use all of them. Do you have an IAT?
Old Apr 9, 2008 | 03:44 PM
93lt1n00b's Avatar
i removed the cat a while back and i put the stock intake back on and its still running shitty im gettin so frustrated this is my DD so im screwed
Old Apr 10, 2008 | 12:09 AM
93lt1n00b's Avatar
anyone?
Old Apr 10, 2008 | 12:30 AM
ineedanls1's Avatar
did you ever check the MAP sensor? or the IAT sensor? both can make the car run like ****...
Old Apr 10, 2008 | 12:36 AM
ineedanls1's Avatar
sorry to say you may have replaced the plugs and wires and opti but i would always check those again...my truck just did this...everyone was telling me oh you need o2 sensors MAP sensors...but honestly i replaced the plugs and bam problem went away...
93lt1n00b's Avatar
im going to purches a MAP sensor tomorow what is the IAT sensor?
Old Apr 10, 2008 | 12:42 AM
ineedanls1's Avatar
Intake Air Temperature sensor it hooks to the intake...elbow...cheap too...replace both still runs shitty...return them...easy at that...
Old Apr 10, 2008 | 12:44 AM
93lt1n00b's Avatar
alright man thanks im gonna go get some sleep and try this **** tomorow
Old Apr 10, 2008 | 11:41 AM
ineedanls1's Avatar
let me know how it goes...
Old Apr 10, 2008 | 02:23 PM
93lt1n00b's Avatar
Exclamation
just replaced the IAT and the MAP and nothing changed still running horible the Rpms keep going up and down! i dunno what to do im stuck! come on theres gotta be somone on here who can help meee
Old Apr 10, 2008 | 02:53 PM
93lt1n00b's Avatar
i also noticed it smells like its running a bit rich
Old Apr 10, 2008 | 03:17 PM
  #32
Burning Rubber's Avatar
Are you positive the firing order is correct? My car was running like some dog **** I did a bunch of **** to it and could'nt figure it out. Then I was like hmmm I am going to go over the firing order and I had two wires switched.
Old Apr 10, 2008 | 03:21 PM
  #33
93lt1n00b's Avatar
yeha im positive because i havent messed with them sence i did the opti and this just happend all of a sudden
Old Apr 10, 2008 | 03:50 PM
  #34
infinitebird's Avatar
do you have any way to scan the car? might tell you what is up with it.
Old Apr 10, 2008 | 03:56 PM
  #35
ineedanls1's Avatar
replace the spark plugs there cheap...might as well narrow everything down...
Old Apr 11, 2008 | 12:59 AM
  #36
93lt1n00b's Avatar
Thumbs down
i just changed the plugs and nothing changed im ready to drive off a clif with this car im so sick of this
Old Apr 11, 2008 | 01:25 AM
  #37
ineedanls1's Avatar
hmmm...EGR clogged? EGR delete time!
Old Apr 11, 2008 | 01:51 AM
  #38
93lt1n00b's Avatar
lmfao i guess im gonna try that tomorow i have so much free time on my hands everything im told to try i just go do it haha 2:51 i guess i could try it tonight any other sugestions?
Old Apr 11, 2008 | 09:47 PM
  #39
93lt1n00b's Avatar
so i put new wires on and it ran great for like a hour i went inside to wash up come back out take it for a test drive running like **** again??? wtf now the old wires were destroyed
im so confused im done for the night but any suggestions
Old Apr 11, 2008 | 09:56 PM
  #40
ineedanls1's Avatar
sounds like the opti then i would just replace it when you replaced it what opti did you put on it??
