Ok guys im having an oil problem.
so now after buying that and a breather cause he said my blow by could be blowing the seal, all said and done im out 2200 bucks and the car still leaks oil. now is there somehting wrong with him, did he screw up and nopt know what hes doing or is my car having a serious problem?
i refuse to put oil in my car every week and im gunna bring it to someone else tomorrow.
regardless, sounds strange that it keeps blowing. are you sure hes installing it right?
blowby then its posible that you have bad rings if thats the case. Are you sure its coming from the same place? Did this guy even do a cylinder leakdown test to prove to you that it dose have excessive blowby? Why did it get head gaskets?
