cc306
Old Apr 10, 2008 | 06:12 PM
slick1851's Avatar
FYI isnt desk top dyno do engine hp not whp
Old Apr 10, 2008 | 06:13 PM
slick1851's Avatar
Originally Posted by Green3spd
what kind of #s are people seeing with the crane 227?
Thats a very good cam
Much better than the other peices of crap people put in there cars
Old Apr 10, 2008 | 06:29 PM
StealthFormula's Avatar
Originally Posted by Trick450r
Yeah after listening to some sound clips and looking at some dyno results im pretty dead set on the 503 now, i will deffinatly be doing the comp magnum 1.6 rrs, the crane springs, and a new timing chain, anything else im going to need outside of the obvious (retainers, shims, gaskets etc) And if i have money left over i might as well put a new opti in.
I'd recommend you go with the NSA Pro-Mags. Cheap insurance that will potentially keep the valvetrain more stable at higher rpm levels. They cost more than the Magnums plus you will need guide plates and studs so it will cost more. Thats another thing where I went with the Magnums myself and now Im getting Pro-Mags and I wish I would have forked out the extra cash to begin with.
Old Apr 10, 2008 | 06:30 PM
Green3spd's Avatar
I like everything about this cam... except that it has NO choppy idle...
Old Apr 10, 2008 | 07:03 PM
C_Rules's Avatar
Originally Posted by StealthFormula
Crane 104227. Its a pretty nice cam with a strong low and mid range. Works real well for the b-bodies because of its nice torque, it helps them get off the line quicker which is why its called an RV cam. Sounds fairly stock which can either be good or bad thing depending on preference and a nice choice for someone wanting to shift around stock rpm levels. I have some more info on it in my cam sticky at the top of the forum.
i had the 227 it was a great cam. i couldn't get the most of it since i had a bunch of knock that i couldn't get corrected until about a year later. by then i had gotten a new cam. i should have waited until i ran the 227 without the knock. anyway even with the knock though the car ran strong and sounded great. pm asandman i sold it to him a while back. don't get caught up on all the "babycam" talk.
Old Apr 29, 2008 | 09:32 AM
Newb's Avatar
so which cam will make more power ? 227 or 503 ? Also, are they both feesable with stock heads ? And how streetable are they ?
Old Apr 29, 2008 | 10:20 AM
Thats not really comparing apples to oranges. The cc503 will make more peak power but the 227 will have more low end power/torque. So it depends what you want out of it, its not all about peak numbers dont forget. Both are great with stock heads and both have great drivability.
Old Apr 29, 2008 | 01:30 PM
phirepower's Avatar
Gm846 is worth looking into, i ran it with stock heads and lt4 springs for a while, i was limited to 1.5 rr's because i was worried about over flexing the lt4 springs. was a nice combo, and emitted a sweet sound
Old Apr 29, 2008 | 04:11 PM
CaramelPleasure's Avatar
Not trying to highjack but how about a cam that has the 227 power(low and mid-range) and the cc503 sound?!! (that works with the stock heads of course)
anyone know if there is one like that?
Old Apr 29, 2008 | 05:13 PM
96capricemgr's Avatar
A custom grind could get you there. Most off the shelf stuff is put on excessively wide LSA which reduces overlap and tames idle with substantial midrange torque loses. Get something say HOT camish but on a tighter LSA and I think you will get what you are asking for. Friend has something much like this and it works well.
Old Apr 29, 2008 | 08:14 PM
Yeah if you want that you should consider going custom, that could easily be done
Old Apr 29, 2008 | 10:07 PM
  #32
where could i get something like that done?
