is there anything direct bolt in better than a Walbro 255?
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
i know i am about nearing the potential of my little 255 intank, would like to stay in tank and was wondering if there are any other options?
thanks!!!
taner
thanks!!!
taner
your not running the spray and motor on it are you? a single walbro is good to about 625 or so rwhp...put a kb BAP on it and you can prolly squeeze 725-750 from it...if you need more put 2 walbros in it...if your runnning yur nitrous add a few degrees of timing back into the motor put a stand alone up front or back and put 116 in it or higher
1 Post
i have a separate fuel system for the n2o.
i have heard of the pump maxing out around 550 rwhp, just what i heard.
with 2 walbro's would i have to run a NEW feed line? i am still running the stock steel line, up until where the factory plastic lines used to connect, from there it is -6 line to the motor.
what is kb BAP? is that a boost a pump? thanks?
Moderator
Walbro also made a 340 in tank pump.
Heres a write up on the dual pump, it's a 98 car with a metal tank should be the same as our cars.
https://ls1tech.com/forums/fueling-injection/856954-diy-twin-pumps-quick-cheap.html
I bought the Racetronix lt1 kit from Thunder. It came with the walbro 340 pump and a boost-A- Harness. Very nice kit, came with detailed colored instructions, gm connectors , fit right in the stock bucket. A lot of people have problems with the feed hose popping off the pump in the tank. The Racetronix pump came with a nice factory style crimp connector on the feed hose.
Not sure on the GPM difference btwn the 255 and the 340, i know it looked bigger.
kb boost a pump yes...personally thats what i would do...before 2 walbros...your kit should have the 340 pump in it...mine came with it about 1.5 years ago...if not i wouldent worry too much i think youll be fine just keep a good clean fuel filter in it and youll be fine to 625...then start to watch it closer
Before Even going 2 Walbro 255s. You guys should be looking into the MKIV Supra Fuel Pump. Flows a lot more than a Walbro, Quieter, and more reliable. Made by denso.
As quoted
"Toyota Supra Twin Turbo In Tank Pump
(Adj FPR required)
260 lph @43psi @12v 290 lph @43psi @14v
220 lph @58psi @12v 260 lph @58psi @14v "
As quoted
(Adj FPR required)
1 Post
does racetronix actually modify the pump? reason i say that is I know for a fact Walbro doesn't make a 340 lph pump for the f body...period! my distributor clarified that for me yesterday when i inquired about it.
he noted he had heard of folks modifying the pumps to flow more lph. that is why i wondered about the options. i believe my pump is wired to the battery, that is something that abortion racing engines did to the car when they first had it....i believe. the reason i say that is i have a fused 8 ga. wire off of the battery which runs to the pump. might actually be something they did right!!! one of a few things.
there really isn't much more to modify the car, but an upgraded fuel system is on next winter's list of mods. that includes an aluminum tank, with an A2000 inside of it, really big a$$ injectors, and have the xfi control the fuel for the fogger through the injectors. will clean up more of what is on the car under the hood.
Yeap.......
https://ls1tech.com/forums/showthrea...ght=340+walbro
As quoted
(Adj FPR required)
As quoted
(Adj FPR required)
ditto, our 1000 WHP supra has gone through 12 pumps, he changes them every season in his triple walboro pump setup. he finally got fed up and teamed up with another company to produce a triple denso pump hanger and has been running it flawlessly. Youll find the walboros are pretty inconsistent and tend to "crap out"
for the money and piece of mind, i rather spend an extra 130$ for a denso than having to replace and possibly damage my motor due to lean conditions
