Who has the fastest stock internals record? and what is it?
my buddy has longtubes ls1 lid 3.23 and 3200 stall went
8.1 on motor(1/8)
7.3 with me petaling it on a safe 150 shot
prolly a mid 11 on that pass...get the 60 down it would go 11.20's...then all it needs is more gear/spray/stall and less weight...id guess the rocrd be about a 10.6
8.1 on motor(1/8)
i doubt the record is 10.6, i think the ls1 record is 10.8 if i recall correctly....
Fran, wow that is amazing!
Beaflag, I figured u would dip into this thread once i made it... im sure u will have a great chance at this record once ur LT1 is all done.... I agree someone should really dig this up or come forward...Im sure it is like 11.0 or so
I've gone 12.24@4500 DA with some bald *** sportman pros 1.89 60"... Stock internal with slowmaster exhaust, stock manifolds, and a TNT 75 wet shot of nitrous... This year will be a whole other ball park... Gone all out with forged internals, and a TC76 on a log kit. Shooting for something fast no telling yet. As I have got a ways to go to finish my build. But I want to see how driving a turbo car with a 6 speed transmission before I even consider an automatic.
Okay I might be able to shed some light on this topic. Back in like 1999 or so I ran 11.40@122 with completely stock internals. 6 speed car, good clutch slicks, 9" rear, 150 dry shot. stock throttle body, stock roller rockers, etc... valve covers had never been off the car. I thought I had the fastest LT1 with stock internals but this was before LS1tech was huge and we had access to all this info. Supposedly there was a guy named Mike (can't remember the last name) that had all the same mods as me but he stripped his car down much lighter. It was a black Z with draglites, one racing seat, and a big *** nitrous bottle where the passenger seat was supposed to be. Well he strapped a 250 shot on his stock internal LT1 and supposedly ran a 10.80 sumthing.... The car's motor expired shortly after that cause I think he attempted to do it again..... Terry Burger (don't know if he's still on here) would probably know who i'm talking about since we were all shooting for the record at about the same time....
I'd say for sure that if you run a 10.80 with stock internals you can safely say you have the record... but it'll have to be faster than 11.0 cause Frans already done that and I went 11.40 and could have gone faster with more spray....
trailblazer ss
my truck at 5100lb w/driver all stock moter power add are supercharger 112/stock pulley3.3@6 psi w/tranns slipping 2/3 ran a 12.19@111.50 going for low 11 after,new tranns,pulley/3.1 for/8psi,75 shot.will be going to track on friday the 18th will post new#'s
#32
Guest
Posts: n/a
Andy Katzelis ran a 10.89@118
http://www.camaroz28.com/forums/show...=andy+katzelis
quoted this as the record
World Record for stock motor on nitrous: 10.86
#34
OWN3D BY MY PROF!
Ok, that's what I'm shooting for then.
I'll have the weight to do it. The only problem is I have a mostly stock suspension, a stock trans, stall, and rear end. I don't expect them to live too long. I already have a 4L80e lined up that I'll build once the stocker dies. Once that stuff is changed out we'll see what it can do.
#35
Well there also has to be some "statute of limitations" on a record. I feel that if the car blew up and hasn't run for 9 years (as in the case of the phantom 10.80 by Mike sumthing) then it's no longer much of a record.... If you run 10.8x and nobody currently actively running (or at least more than 2 years old) then you are the record holder.... my .02 at least
#37
i dn guys i feel like if u make the run u make the run.... u just need to have the time - slip i hope people can be honest about these type of things... i mean where would the satisfaction be if u lied about the time u ran or ur setup? thats just plain stupid
#39
I should've put money on it LOL
#40
Then you would have lost money. Because techniqually you said:
The LS1 F-body recently set a new stock internals record of 10.6 @ 122 and that's with no power adder at all.
https://ls1tech.com/forums/drag-racing-results/879218-new-stock-internals-record-10-685-122-91-a.html
I'm not sure what the stock internal + N20 record is for the LS1 but I bet it's in the 9's or real close to it.
