Buying LT1 Tuning Software and Cables
Would it be better to buy a mail order tune or to do my own? Dumb question.
Just wondering how much it costs to get setup with all the stuff to do your own in the end...
Thinking about CunerTats.
-Rick
You'll need an ALDL interface cable to connect your PC to the PCM. You will
need a cable from AKM Electronics (www.akmcables.com), TTS Power Systems
(www.ttspowersystems.com) or Craig Moates (http://moates.net). And you
will need "Tuner". I've sent an email to the TunerCat folks to ensure what
is required. RT-Tuner can not be used, so all that is avail is Tuner.
As far as whether to have it tuned versus DIY - that would be a decision
that you have to make. If you feel comfortably, technically, and want
complete control over the car, and to be able to readjust any setting at
any time you well please, then the DIY route is the way to go.
consider how much possible anguish there would be in trying to learn all the parameters to successfully tune......I think the email tune's the way to go.
yeah, maybe as I have more time to read & study up on 'how to tune lt1's' I'll bust off my own tune somewhere down the line.
The car doesn't run bad, it just seems to be a little rich and could probably use some timing adjustments and such.
How do the credits work for TunerCats? Is it something like HPTuners?
-Rick
-Rick
making any changes, that way you can back into a previous tune.
Initially, take things one step at a time, until you feel comfortable with multiple
adjustments. The best approach would be to change one setting and flash it.
Test it out - depending on the setting that was changed, maybe drive the car for
a couple of days to see the net effect. Then go on to the next setting change,
I'd refrain from doing more than one setting at once, especially when first starting
out with tuning - if you change more than one setting and something gets borked,
you might not know which chang goofed things up.
Matt
with a MOT is that I want to make a change RIGHT NOW and I want to do it with
less impact to my pocketbook. I might want to see if I change *this* value, what
is the net effect to how the car runs. And so on and so forth. And I will have spent
less money for the software and hardware than with most MOTs.
Personally, it's more about "doing it all myself" and being in complete control of the
car; plus, it's also about understanding how everything works together as a unit.
Sure, I understand that many folks would rather view their car as a "black box" and
not have to worry (or want to know) how everything interacts. The other advantage
is that self-tuners can log data over a period of time to assist in troubleshooting,
pull codes, and so on.
With that said, I ordered TunerCAT last night and downloaded the program - all I
have yet to do is build the cable and I'm in business.
although I was responding to your opinion, I was expressing an opinion for the
benefit of others, to give them something to think about. There are many people
that just lurk, so for those folks, the more information, the better.
