fuel problem
Old Apr 23, 2008 | 10:22 PM
1lt1wiz's Avatar
Exclamation fuel problem
i have a 94 camaro with free mods tunning 323 geers and a slp loudmouth1 i put a full tank of 89 fuel and its gone in one day not even beating on it help i have exhaust leek at the manafold any help will be helpfull
Old Apr 24, 2008 | 10:17 AM
1lt1wiz's Avatar
anyone
Old Apr 24, 2008 | 11:02 AM
sweet-94z28's Avatar
Check your fuel pressure regulator. It sounds like it is pouring fuel through it. Does your oil have any gas in it? Does it smell super rich or run poor?
Old Apr 24, 2008 | 11:18 AM
djjab57's Avatar
I ran the lower oct. once what will happen is it will cause a knock sensor the ajust the timing retard and make it use more fuel than it needs some one on here can explain it more in detail than i can im sure
Old Apr 24, 2008 | 11:22 AM
1lt1wiz's Avatar
i have the lt4 knock senser the car is liking oil in the back of moter i all ready had the frount main seal fixed
Old Apr 24, 2008 | 12:47 PM
robsquikz28's Avatar
pull a plug and c if there is fuel all over the plug and check for some leaks you should get bout 180+ miles to the tank and check your fuel psi regulator stick a fuel psi gauge as well and c what ur at while running.
Old Apr 24, 2008 | 01:42 PM
ss.slp.ls1's Avatar
Any codes?
Old Apr 24, 2008 | 01:45 PM
355z28's Avatar
Well having an exhaust leak right at the manifold you make it run rich with the cold air coming in, like stated above your fuel pressure regulator could be bad pull the vacuum like off and if fuel comes out your in need of a regulator, also if you have more then 50k on your o2 sensors id just recomend changing them out for new delcos anyways but they could be causing you to run rich also.
mass air flow sensor could be dirty, or i believe the map sensor will also make it run pig rich if its not reading.
Old Apr 24, 2008 | 01:51 PM
LT1-DAN's Avatar
Did you check the pcm for any codes?
Old Apr 26, 2008 | 12:56 PM
1lt1wiz's Avatar
should the car be running or off
Old Apr 26, 2008 | 06:09 PM
ss.slp.ls1's Avatar
Prime the pump by putting the the car in koeo. Then pull the vacuum line off of the fpr and look and smell for fuel. If fuel is present, you have a faulty fpr diaphragm.
Clean the MAF wires with electronics cleaner.
