So what are the pros/cons of deleted the A.I.R system?
Pros:
Weight removal of the system
More space under the hood
Cons:
The AIR system's whole purpose is to increase the longevity of catalytic converters. If you don't have cats, there's no need for the AIR system. However, if you use a cat/cats, you should leave the AIR system in place IMHO.
Removal consists of taking out the AIR pump (driver side front of engine) and all associated tubing/hoses, and plugging a fitting on the driver side of the intake manifold. The PCM also needs programmed or you'll have a DTC.
AIR = Air Injection Reaction
PCM = Powertrain Control Module
DTC = Diagnostic Trouble Code
Cons:
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
nope you shouldnt get a ses light either.
hey do they visually inspect your car at emissions? if so you might fail with it gone but you have LT's so i guess it wouldnt matter because you would fail with those. unless they just hoook up to the computer like here in wisconsin
I did this recently after the header install. Makes for more room to periodically check torque of the headerbolts. It is way cleaner under the hood. I don't have yearly inspections where my car is registered, so that is something to check on...
Hi guys, sorry to dig up this tread. I have the same question: will a ses light be displayed for a 1995 LT1 car if I remove the Air injection? I know 1995's have OBD1 so I shouldn't have any problems right?
when i deleted it on my 97 i did get a check engine light but i didnt get it until about a month later, odd... i just had the light tuned out by a local tuner that has the LT1 software
