LT1 to gen1 conversion
Old May 3, 2008 | 01:53 PM
supernova's Avatar
Default LT1 to gen1 conversion
Hi, i am new to this forum and hoping to get some good info from its members. I am currently restoring a 76' chevy stepside pickup and have a strong running 5.7 in it right now. I would like to do an LT1 intake swap on it if possible. I already have a set of 12558062 vortec heads to bolt on to it, and just found an LT1 out of a 96' camero at my local j/y. Talked the guy down to $100 bucks for the whole top end, wiring, and ecu. Pretty sure thats a smokin' deal. But i want to make sure before i get it that i am not dreaming about making this work. Done some searching and found a few threads but not enough info that im looking for. So if anyone has some advise, or suggestions please help me out.
Old May 3, 2008 | 08:07 PM
BoostedZ28's Avatar
Here's a link to someone that does the conversion so you can fit an LT-1 intake on a 1st gen motor: http://www.lt1intake.com/services.htm
Unfortunately, he claims the conversion cannot be done to work with the vortec heads.
Old May 4, 2008 | 07:33 AM
96capricemgr's Avatar
The LT1 pcm needs cam position info it gets from the opti, so to use it on a Vortec motor you would need to somehow get the optical portion of the opti into the distributor, it IS possible but not a simple project.
Old May 4, 2008 | 05:58 PM
supernova's Avatar
According to this guy the LT1 intake will not bolt up to the Vortec heads.http://www.lt1intake.com/services.htm
