Can't break the LT1
Why are there only a few about people blowing up/ breaking their LT1?
Installing a cam, heads, nitrous, blower, or turbo puts added stress on your motor. These things had to have broken some LT1s.
I ask this to help people better decide what mods are practical for their situation, and the consequences that come with them.
This may help to eliminate the bad rep that nitrous has.
Or stop someone from spending $2500 on a heads cam swap for their 140,000 mile motor.
Think of the people looking at the LT4 hotcam kit, they would probably feel more comfortable spending the extra money on a better setup if they knew they would not have to spend that money to fix their car.
Please, post up your story. What were your mods? what happend? what 90% of the threads on here are about people modding their LT1.
Please, post up your story. what were your mods, what happend, what caused the problem?
Thanks.
Thanks.
I'm hoping for similar results with my 500+hp 396. Granted, we had to take a few extra steps to ensure durabliity all round... but I'll probably "upgrade" to a crazy turbo setup before this combo gives out (I'm hoping at least
).Bolt-ons rarely cause problems.
A poor cam swap can kill bearings, but a vast majority of the time this is installer error.
Nitrous hits of 100 or less seems to have good reports... if it has some miles on it I'd just window switch it higher (say 4000) and maybe stick to 75. I kn ow that's not fun, but its realistic. Especially with the stock pump, which tends to go SOFT before it actually DIES. A Hobbs swtich on the fuel line (or a new pump
) should help from nuking the engine.You could do a small 6psi boost application, but with a stock block with heavy miles you're really just asking for trouble. Wait to do that install on a new engine IMO.
Best idea? Bolt-ons, drivetrain upgrades, suspension, and a stereo.
Leave the engine for second last (paint/body should be last IMO... but everyone has to decide for themselves).Whatever you chose to do...do it RIGHT the FIRST time... and no, that won't always be the cheapest/easiest route.
I suspect that you dont read much about folks breaking their engine because
most people will do research and ask questions before executing a particular
mod (or set of mods, or an engine rebuild), to ensure they're doing the right
thing (of course, that's not to say they wont overdo it after the fact).
I did spin rod bearing in a stock shortblock a few years ago but it was cammed for like 35K miles and then the current heads and cam for another 6-7K and had something over 100K total miles on it IF the junkyard I bought it from was honest when they sold it to me as a 40K mile motor, oddly though seems everything they have is 40K miles. I believe if I had put a fresh oil pump relief spring in it when I did the heads and cam it would still be alive. I had some fuel system issues and such with that motor along the way and over the years some bad tuning it went through hell.
Keep the cams/rpms reasonable, the nitrous shots say 175 and below and the stock motor works increadibly well, BETTER than some of the junk guys are buying as performance engines even.
Far as milage, we cammed a friend's 160K mile former police car coming up on 2 years ago, is his year round daily driver and when we attended a big Impala gathering his cam only car 500 miles from home ran within .1 of a trailered Golen stroker car.
Another friend was spraying 175 shot at his heads and cam Impala for a couple seasons and only finally broke it when he got greedy and put in the 250 shot, nobody intelligent will blame the engine there, even he will admit he just went too big on the shot, operator error.
you'll see the occasional "coolant level sensor light stays lit" threads, and folks
will say, "just disconnect it". I don't care if the sensor *is* $45, it's better
to spend that on a new sensor than $4500 on a new engine or having to
spend the weekend and money on an upper-end gasket set to replace a
blown head gasket (or whatever else).
I guess thats what you could call what happened to my car. 145k stock block, was doing great with bolt ons and cam until i spun a bearing(s). Trans (stock trans/stock shift points) was slipping and rpms would jump to 6k between shifts. Racing the car and the motor gave out. At first i thought it was mainly because of the trans shifting so high, come to find chunks of a chewed up oil pan gasket and all rod/main bearings spun and eaten up. I had recently replaced the oil pump with a high volume, and the thing showed no apparent problems and lasted months. I guess somewhere in the installation, the gasket got torn, and eventually just got sucked into the pan.
The motor would have lasted much longer judging by the look/condition of the internals other than the bearings and cranks surfaces and the parts that were removed during modding (i.e. valvetrain, timing chain, etc.)
leaking coolant out. The temp gauge rose a bit, then settled back down.
Eventually, the car ran like cr@p and so I pulled over and then noticed steam
pouring out from under the fenders. The cooling system was pretty much
empty at that point. The coolant temp sensor was reading the air around it,
since there was no coolant.
Y'all can do what you want - I'm keeping my senses and keeping all my sensors
The sensor is needed for people who are passive, drive their car and just put gas into it. For people like me that are active in their cars fluid levels, ect. we really don't need sensors, because we will spot a problem before a sensor does.
But I agree with you. The added insurance of a working sensor never hurts.
