header with no gaskets to head
Old May 9, 2008 | 08:43 AM
lt170chevelle's Avatar
Default header with no gaskets to head
how many you guys running no gaskets on your header flange where it meets the head? rtv silicone best sealer for this setup?
Old May 9, 2008 | 08:58 AM
Stroked96Bowtie's Avatar
FWIW...gaskets are too cheap and it would prolly take you longer to get the silicone on and sealed than to just slip a gasket in there. Im not sure silicone will hold the pressure like a gasket will. Plus a header gasket thats leaky or excessively leaking will cause damage to the heads. I recently had to change mine, paid a little more for a better gasket than what was on there so I wont have to do it again or for a long time at least.
Good luck either way.
Old May 9, 2008 | 09:00 AM
caldercay's Avatar
Fel-Pro 1470.
Old May 9, 2008 | 09:17 AM
yardd0g24's Avatar
Originally Posted by caldercay
Fel-Pro 1470.
The fel pro 1470.... haven't had any problems since I installed the headers a year ago.....
Old May 9, 2008 | 09:36 AM
armyracer11's Avatar
Thats a dirtcar trick cuz they constanly working on engines, you really dont want to do it b\c that doesnt last long at all.
Old May 9, 2008 | 12:03 PM
ok thats what i was thinking. somebody mentioned doing the no gasket thing but i was pretty leary.now do you think the felpros would be a better choice over aluminum gaskets for any reason?
Old May 9, 2008 | 12:29 PM
camar0corey's Avatar
I can tell you I blew out a percy's aluminum gasket. Kinda expensive if one of the bolts come loose. I know on their package it says they won't get wrecked, well thats just not true.
Old May 9, 2008 | 01:15 PM
StealthFormula's Avatar
I've always ran the fel-pros on both my cars and havent ever had an issue. I think I used the 1406's.
Old May 9, 2008 | 01:22 PM
caldercay's Avatar
1405? That's the square port model. The 1470's are the D-port configuration.
Old May 9, 2008 | 01:49 PM
1406's are D-port
http://store.summitracing.com/partde...5&autoview=sku
I have used them on both cars and they've worked great. Thunderracing sells them in the gasket section for LT1's.
Old May 10, 2008 | 02:15 AM
daniel6718's Avatar
i hear the best thing to do is silicone metal to metal...
myself havent ahd problems with felpro stock carbon gaskets
