355 is slowww
Old May 14, 2008 | 08:04 PM
dre2013's Avatar
Default 355 is slowww
ok heres some history/info:
i had the motor in my 95 t/a that was totalled...sold the eng/trans to a friend of mine who swapped it into another 95.
it is a 350 lt1 bored .030,(355ci). stock crank, and i forget the brand of the pistons. heads are ported,polished and milled.
it has a cc503 cam (224/230), comp 918 springs,
bbk 58mm tb, 42lb injectors(i told him not to get that big.),
edelbrock intake manifold.
pacesetter LT's, no cats, hooker muffler.
spec stg 3 clutch, balanced aluminum flywheel,stock 3.42's
has new msd opti, cap + rotor, msd coil, new plugs + wires(week ago)
Everything on the motor is pretty much brand new. the motor itself had 5k on it when i sold it to him, and he just got it running/tuned, so it probably has 6k miles on it at the MOST.
New fuel pump + filter
It was dynotuned, but because of a problem with it hesitating @ around 4200+rpm's they couldn't finish the tuning. The car runs great up until 4200 rpms, even at WOT. we are trying to figure out what the hesitation problem is. When he explained it to me i was thinking ignition problem, but the whole ignition system is new except for the ignition control module(and my understanding of those is that either they work, or the car doesnt run..correct me if i'm wrong). Now im thinking it could be a fuel problem, but everything in that department is new too!!
anyone have any ideas? sorry for writing a book but i wanted to make sure all the needed info was there. Thanks,
James
Old May 14, 2008 | 08:06 PM
dre2013's Avatar
also, while @ WOT when it was hesitating i noticed what looked like black smoke in the rearview...is it possible that even though the ecm is tuned for the 42lb injectors, they are still too big and are just dumping fuel?
Old May 14, 2008 | 08:09 PM
BsGreenZ's Avatar
black smoke is rich.. i would go down to 30lb injectors and get it retuned.. But i'm not really sure..
Old May 14, 2008 | 08:24 PM
95ZRagtop6M's Avatar
I'm running 42lb Lucas injectors with similar mods and mine passes NJ emissions. Do you have a data logger? You might want to invest in one if you don't have it. I'd be curious to see what the MAF is doing?
Old May 14, 2008 | 08:35 PM
dre2013's Avatar
i told him to go with 30's in the beginning...and then all of a sudden he tells me he put 42's on it...i informed him at the same time that another friend of ours has an lt1 with an sts rearmount that has 42lb'ers. unfortunetly we don't have a datalogger right now...the car has a brand new granatelli MAF on it...forgot to mention that
Old May 14, 2008 | 09:00 PM
nomoneyz's Avatar
I've heard a lot of problems with those granetelli maf sensors. Most everyone says keep it stock.
Old May 14, 2008 | 09:01 PM
yep 30's will certainly work. I was at about 19ms (over 90%) duty cycle on my 30 SVOs. I have an NOS dry kit I'm planning to put on, so I upgraded to 42's. Interestingly, the car idles better and runs smoother with the 42 Lucas than it did with the 30lb SVOs.
Do you have a stock MAF to try? If you can get a datalogger I would check the MAF, trim values and detonation hits.
Old May 14, 2008 | 09:19 PM
dre2013's Avatar
thanks for the quick replies, we do have another stock maf to try, but i doubt we would be able to get a datalogger as of right now...he spent a lot of money building the car and is almost tapped out as far as cash goes
Old May 15, 2008 | 03:19 AM
speed_demon24's Avatar
Puffs of black smoke is also a sign of detonation.
Old May 15, 2008 | 10:07 AM
MEAN LT1's Avatar
Im interested to see what the maf tables look like as well. Its very easy to put in the wrong number when your working in those tables. Ive done it a couple of times mmy self.
Old May 15, 2008 | 10:30 AM
LT1MAN's Avatar
i dont see 12 lb difference in injector size being the issue.
Old May 15, 2008 | 12:04 PM
Formula96's Avatar
i would look at the icm as the culpret
https://ls1tech.com/forums/lt1-lt4-modifications/919806-opti-not-problem.html
Old May 15, 2008 | 12:11 PM
dre2013's Avatar
thats what i was thinking too...would the one from my 93z work in place of his? just for testing to see if that is the culprit. i just put a new one in my car 5 days ago. His is a 95 t/a m6...mine is a 93z28 a4
Old May 16, 2008 | 12:25 AM
dre2013's Avatar
bump..
Old Jun 19, 2008 | 02:17 PM
dre2013's Avatar
car still has the same problems...tried swapping out ICM's, no change.. put an lt4 knock module in it, no change... the car does have a granatelli MAF on it and ive heard people have had problems with it. should i try swapping it out for a stock one? any ideas at all?!??
Old Jun 19, 2008 | 03:04 PM
chavez885's Avatar
Yes, granatelli MAFS blow, change it and see what happens.
Old Jun 19, 2008 | 04:20 PM
95 Formula's Avatar
do you have an ignition box(msd 6a, etc)? I had the same issue at 5200 rpms years ago when I first built my motor and put a box on it and the problem went away.
Old Jun 19, 2008 | 05:38 PM
dre2013's Avatar
hmm... i was going to get a mallory 685 to go along with the nitrous, but i was hoping to wait at least a few weeks before doing that. I am going to swap MAFs in about an hour and i'll post back. thansk for the help
Old Jun 19, 2008 | 05:53 PM
I8ASaleen's Avatar
Change that MAF!
Old Jun 19, 2008 | 05:58 PM
slammer454's Avatar
i'm suspecting the MAF as well, I haven't heard many good things about them.
