OMG!! plz help
Old May 19, 2008 | 10:15 PM
lt1noob's Avatar
Originally Posted by lt1 hawk
I really wish people would quit using texting shorthand...
agreed
Old May 20, 2008 | 12:19 AM
performabuilt's Avatar
LS1Tech Sponsor
Originally Posted by gatorhead
Do what ya want, but for the money and headaches I searched abroad and came across Frank with PerformaBuilt. He made me a custom stall and a kickass stage 2 tranny that handled 600 ponies like it was nothing! For the price you can't get any better IMHO!
Thanks
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old May 20, 2008 | 02:02 PM
SprayedZ's Avatar
Wow they are expensive But i guess if it holds up that will work. I went out this morning and the my car drove around for about a minute and then everything was gone so i think i fried the clutches or something.
Old May 20, 2008 | 02:35 PM
ws6t3rror's Avatar
I think you have a big fluid leak somewhere. Or it could be something as dumb as low fluid, have you bothered to pull the dipstick and check the state the fluid is in and make sure its full. Does it have a dark brown or orange look and smell pungent?
If the fluid still looks fine, maybe its something more simple like the turbine shaft seals on the input shaft. if they cross leak it will have the clutches opposing each other.
Old May 22, 2008 | 12:54 PM
SprayedZ's Avatar
I dont know i dont leak well it leaks like a two or three drops around the pan it is just a little and the fluid is not Brown but its not brand new either and it does smell burnt. So i am going to change the fluid and the filter and put back in my stock convertor next weekend and see what it does. I think that will answer alot of my questions.
Old May 22, 2008 | 02:14 PM
ws6t3rror's Avatar
By leak I meant internally around the teflon turbine shaft seals. Not like out of the trans onto your driveway. Its already kicked the bucket though imo. Hope the stock converter and filter change isnt a total waste of time but i'm fairly certain it is.
Have the converter you already bought cut cleaned and inspected though when you have it rebuilt assuming its a good brand name.
Old May 26, 2008 | 06:32 PM
SprayedZ's Avatar
OK now that i let it cool down it drives for about a minute and it does fine, then it has nothing what would that be????
Old May 26, 2008 | 08:19 PM
the_merv's Avatar
Veteran: Air Force
Time for a new Tranny basically, I wouldn't even waste the time ****** with it.
Like mentioned..there are some good guys here that can build them real well. They are not cheap either.
A good build will last.. I had my first 4L60E "built to handle" my 402 by a local guy..two passes down the 1000ft Track I shattered the Sprag, ballooned the Sunshell and Reverse Drum causing 3&4 Clutches to fly apart. Basically I had nothing past second.
I got a friend that runs a Tranny Shop locally and one of the guys there that used to build Race Trannies hooked it up with some tricks, that thing is a beast now. With a 3600 Stall it does good enough to pull consistant 1.56 60 ft's.
Old May 26, 2008 | 08:40 PM
94CamaroZ28SS's Avatar
Originally Posted by SprayedZ
No first and second are great it launched i got a 1.80 60 foot. It is just in 3 and overdrive. i will be in 3 and give it some gas and it will just go up to like 5000 or 5500 and it is just SLOW like something is sliping and then if i kick it down it is gone?????
I had this problem.....i had mine rebuilt with a shift kit no stall though.......after like three months i had the same symptoms as you and i took it back to him and he re opened the tranny and said my 3-4 and overdrive was gone so he replaced it and i havent had a problem since!!!!
