95 lt1 camaro
Old May 27, 2008 | 08:16 PM
fast414's Avatar
Default 95 lt1 camaro
will a set of welds, prostars or draglites fit on my 1995 camaro ....thanks
Old May 27, 2008 | 08:32 PM
95camaro383's Avatar
i have prostars on my car in the front 3.5 wide i had to use spaces no quite sure what size and the backs are 15X8 with the wrong backspaccing not sure of the exact
Old May 27, 2008 | 10:29 PM
BOLO's Avatar
Weld Draglites/Prostars-15x3.5 w/1 3/4" bs
15x8 w/ 5 1/2" bs or 15x10 w/ 7 1/2" bs
Calipers will need grinding front and rear.
Old May 28, 2008 | 01:51 AM
LT1's Avatar
LT1
lot of some BFH for the rear with 15X10.
Old May 28, 2008 | 12:58 PM
Razor_Blade's Avatar
No BFH on mine with 15X10, 7.5 BS and MT 275-50-15 radials.
Old May 28, 2008 | 04:18 PM
LT1's Avatar
LT1
oh ok probly because you ran 275's
i wasnt nowhere close to fitting 325's without lots of BFH and inner fender lip rolled.
Old May 28, 2008 | 04:21 PM
Formula350's Avatar
Just to comment on the caliper grinding: It's the fins you grind down. If I knew where Merv's pic was, I'd link it. Maybe he'll stop in here by some odd chance (or you could PM him too the_merv)
Old May 28, 2008 | 10:46 PM
the_merv's Avatar
I'm here..here it is..
This is the Grinding that I had to do on the Rear Calipers to get the 15" Draglites to clear..
I have LS1 Brakes on the Front. I used a 1/4" Spacer and haven't had any problems.
This is the Car on the Rims.. I need to get a better spot with a better light angle and take some more pics. I'm running 275/50R15's MT ET STREET DR's.
