Hit a snag...
Old Jun 1, 2008 | 12:19 AM
disiac5.7's Avatar
Default Hit a snag...
I just replaced the opti on my z28. I got the MALF 16 or whatever it is code. So I just finished replacing the opti and the car turns over, has spark (checked plug wires) and you can smell fuel coming from the exhaust. But it won't catch.
Any suggestions? I'm going to put the data logger on and try turning it over tomorrow, hopefully I can pull a code...
Old Jun 1, 2008 | 12:40 AM
Fixxer99TA's Avatar
Just curious, which opti did you replace with? Factory Delco or other?
Old Jun 1, 2008 | 12:51 AM
disiac5.7's Avatar
ACDelco. I was advised to stay away from any other type.
Old Jun 1, 2008 | 01:06 AM
Formula350's Avatar
Delco bought from where?
Old Jun 1, 2008 | 09:55 AM
disiac5.7's Avatar
I bought the opti from summit racing.
Old Jun 1, 2008 | 10:44 AM
30696bird's Avatar
Summit has their own opti........are you SURE it's an acdelco?
Old Jun 1, 2008 | 11:47 AM
Dadic 78's Avatar
I'd check your plug wires. Sounds like you might have got a couple of them in the wrong order when reassembling.
Old Jun 1, 2008 | 11:52 AM
BattleShip's Avatar
Clear the code. Are you using Datamaster? DTC 16 is low res.
Clear and collect again. Put the file on here
Old Jun 1, 2008 | 12:06 PM
disiac5.7's Avatar
The summit brand is $250 and the acdelco is $310. I paid $310, so I'm sure it's the ACDelco. The code is gone, no codes at all right now. It might be bad gas? I am pretty sure the wires are on right, but I will have to go check (again). I'm not terribly worried anyways with the gas prices as is, I don't think I want to put premium in a s/c 350
Old Jun 1, 2008 | 12:20 PM
BattleShip's Avatar
Does it start or hit at all? Do you have datamaster? Did datamaster indicate code is cleared?
Old Jun 1, 2008 | 01:41 PM
disiac5.7's Avatar
No codes at all. Datamaster-EE. All the vitals check out and are fine, the only thing that worries me is that I have less than 10 volts when cranking. It usually is between 7 and 10 volts.
Old Jun 1, 2008 | 02:52 PM
BattleShip's Avatar
That voltage is ok when cranking (7 is low but as long as it cranks--ok). Does datamaster show the rpm changing, map, injector dc?
Old Jun 1, 2008 | 06:59 PM
disiac5.7's Avatar
It's reading everything... Inj pulse, spark adv., etc. The rpm is staying constant @ 50 rpms I believe, the laptop took a dive on me and I need to charge it to get some info.
I didn't notice this before, it's showing knock count when cranking. My best guess right now is plug wires, cuz when I switched two of them (3 and 5) the car almost started. They are such a PITA to reach with the vortech in the way.
Old Jun 1, 2008 | 07:12 PM
BattleShip's Avatar
Mine cranks at 125 then starts. Check the data.
Old Jun 1, 2008 | 09:12 PM
disiac5.7's Avatar
The rpms do start at 125 and go up, 150 to 175, down to 75, 125, 175, 200, and so forth.
The data I pulled:
RPM/RPM16: 175/175
MAP KPa: 94.1
Fuel Trim Cell: 0
LTerm Counts: 128/128
STerm Counts: 128/128
BPW mS: 29.24/29.24
INJ DC (calc): 4.3/4.3
o2 sensor mV: 781/879
AFGS: 0.00 <------------- MAF reading 0 gm/sec?
TPS %: 0
TPS volts: .67
Spark Advance: 13.0
Spark Retard: 0
Knock count: 1622 <----- this is my worry
EGR DC: 0
CCP DC: 0
IA Temp in Celc: 24.5 degrees
A/C Temp in Celc: 20.0 degrees
A/C Press PSI: 84.0
Idle RPM: 3188 <----------wtf?
IAC Pos: 154
Old Jun 2, 2008 | 05:26 PM
BattleShip's Avatar
ok no problem
The data I pulled:
RPM/RPM16: 175/175
MAP KPa: 94.1
Fuel Trim Cell: 0
BPW mS: 29.24/29.24
that is WAY high! Mine cranks with and starts with ~8 ms
mmm mine is ~2 but I have 42 lbs and it is started at that point
well that implies it is hitting since low is lean and missing is lean
normal until it fires up
TPS %: 0
TPS volts: .67
Spark Advance: 13.0
Spark Retard: 0
all normal
not to worry it starts at some point meaningless until the number changes
EGR DC: 0
CCP DC: 0
A/C Press PSI: 84.0
all normal
normal
IAC Pos: 154[/QUOTE]
ok
Old Jun 2, 2008 | 08:45 PM
disiac5.7's Avatar
what would cause such a high BPW?
Old Jun 2, 2008 | 09:00 PM
BattleShip's Avatar
have u changed the tune? Changing the tune cod easilly do that
Old Jun 2, 2008 | 09:39 PM
disiac5.7's Avatar
I haven't touched the tune. Bryan from PCMforless put a base tune on it and I took it home and started working the bugs out.
Old Jun 2, 2008 | 09:53 PM
BattleShip's Avatar
has this tune run before in your car? I would try a stock tune if this hasnt run in your car before.
