Possible new Intake manifold for LTX
#41
And why do think all the guys that own TPI motors ditch their long runner intakes in favor of a Steath Ram, LT1 intake, of Single plane conversion?
#42
Because the TPI's runners were around 24inches long, and they had a hard time making hp even in the lower rpm ranges. There is a nice medium between runner length and plenum volume. I think intakes with runner length in the 6-8inch range work well in our cars. Gives a better TQ curve and still makes as much hp as the small runner intakes.
#43
From my understanding the designer of the LTx motor wanted a longer runner intake manifold but for some reason Gm didn't correspond and gave us the intake we all love so much.
Just looking at one variable of intake design (runner length) The LSX intake manifolds are around 7-8inches, the stealth ram is 6inchs, most single planes are around 6inchs. Judging by all the graphs I have seen, these intakes really dominate over intakes with smaller or larger runners. Then again things like plenum volume, cross section, etc come into play as well.
#44
Ive considered switching to 1gen motor and using the stealth ram to keep FI. http://www.stealthram.com/phpBB3/ind...be7124a5241536
#45
Hahahah is call stall converter...when it flashes 3500-4500 rpms ......your car must be a stocker slow car....what do you think guys race by going from 1000-2000-3000-then to 4000+ rpm down the track or street?....NO, that would be SLOOOWWW ......they put the car in the beginning of the power band and take off hard......you must be retarded.... I guess I must be dealing with fast cars and your not used to that.....
#47
I don't goto the track, so yes my car is slow in comparison to you who dump money into yours. So torque matters to me. I also cant imagine that even with a stall that torque plays no roll in getting you out of the hole.
I also don't read any car magazines, so I'm sorry to disappoint.
#49
The HSR is sounding pretty good for when I get my car back together. What does it cost to have the bolt pattern changed?
and torque is pretty damn important at all rpms, to state the obvious that's why we get the jump on most imports even in a roll race
#50
Its around 200 for the bolt pattern. You also have to cut the wiper cowl and theres no way its fitting under the stock hood. I dont have wipers anymore, so rainx is your friend. It also use aftermarket fuel rails, so I run braided from under the car to the rails.
#51
Or am I mistaken?
David
#55
And just because I don't goto the track, nor read car magazines (they're biased anyways) doesn't mean I don't know stuff. I've been working on cars for around 8 years now. Not always huge tasks, but they were always a learning experience. I also read a ton of stuff else where, technical documents and user experiences. So to say what you said, is completely ignorant.
With that said, horse power is actually the bi product of torque. The formula is thus: HP = TQ x RPM / 5252
/ as in fraction, not divide.
#56
The intake was supposedly sold. So it may get used I dont know.
It was a GM 350 Ramjet crate engine intake that was sent to Wilson and had the top cut off and a new top put on for a Monoblade, it was also cut down to fit under the cowl.
The whole situation was really sad.
David
#57
No that wasn't me, and Ram Air IS fairly useless until you're going over 70. Until then, a proper CAI will give you the same results. If you really want to get technical about it, for Ram Air to work in all meaning of the term you have to be going Mach 3. On the flip side, that's a Ram Jet which doesn't use turbines or ignition source (like spark plugs), but just Ram the Air into the front of them and a conical piece in the intake compresses it to the point of combustion. Moving along...
I respectfully disagree, but will not go into it here in this post.
Guys on this board have done a few VERY good tests here as of late to prove Ram Air works.
And yes you were in one of the posts where the discussion was on Ram Air, you said it didnt work.
And BTW working on cars for 8 years means nothing, I know guys that have done it for 25 years and dont know crap about Hot Rodding, testing theories or racing. All they know how to do is work in the dealership environment.
WHen I took my car to the Chevy dealer where I write service, the majority of the techs were dumbfounded that I was still on factory electronics, opti and that I drove the car 25 miles to work on pumpgas.
David
#58
David
David
As for CAI and Ram Air, the gain isn't much, so who cares? In all honesty, if I got a hood, I'd get the Ram Air, but until then I'll just stick with CAI.
I remember your falling out. I don't remember if you ever got to use that intake ever though?
#59
i got a victor jr. e...and it fits under my stock camaro hood...and its got a nitrous daves elbow on it to........
