Fluid leak, need help.
Heres the problem: I left for work today and came home to see a 1 foot in diameter spot of fluid. It was mainly clear but had a shade or reddish/brown to it. It was sticky to the touch and it was directly under the engine bay. All i know is that I have not seen any leaks while under the car changing oil etc. Today, while I was on my way to work, the low coolant indicator came on but after work when I left, it did not come on again. The only other thing i know of it that a mechanic said my freon level was a lb low. Please help. Thanks.
I just changed out the trans fluid over the weekend and it was not leaking, it is mostly clear and its not really close to the transmission at all? Could it be dex-coolant?
