LE1 h/c track times
If you're looking for an emissions legal combo that'll run well and be as dependable as stock then IMO you'd be better off w/ a Lingenfelter setup.
PS, mine is am emissions legal set-up that barely cracks an 11.90 on a good air day in Chicago.
There's nothing pricey about the LPE setup. If LE had the same kind of quality rep as LPE then his prices would be quite comparable. People can take the gamble and go w/ a LE head and have the troubles that we've all read about and seen on these boards or go with a CNC head that makes excellent power/torque.
P.S. Do you have any idea what compression ratio you would get out of a 60cc chamber with -5cc stock pistons that are .020 in the hole with a .039 head gasket?
P.P.S. John did not give two ***** about the LTx engines once the LS1 was on the market. He was in the dealings in making one-hundred Lingenfelter/Hurst Firebird packages that contained the LT4 heads, intake/Edelbrock headers/211/219 cam/gears, but abandoned the project when they got their hands on the LS1.
And there were LPE/Hurst Firebirds made.
EDIT: Alright I see what the problem is. I added 5cc for to head chamber for the valve reliefs and with that all factored in, the stock LT1 with Impala gasket is 10.66:1 which is much more accurate. With that in mind it's somehow now 10.28 heh
However... when entering your piston cc area some read the "-" sign as less area and others calculated it as more.
The heads however might be considered stage 2s. I don't know as they where done before Lloyd started using stages.John didn't give a what about the LT1? I didn't know you knew him well enough to speak for him.
