im stumped, can anyone help?
If it doesn't post again I suspect it will crank but lets wait and see. Do NOT turn the key on that way it wil crank but not start.
Be CAREFUL not to short the wire to any metal don't make this a bigger problem
and point the problem to the ignition switch and vats...another way is to remove the wire and have someone hit the ignition key. The solenoid wire should go to 12 volts when key os turned to start position..
your choice
with the key turned the solenoid to ground on the starter is reading 12.17 V and at the battery it is 12.57... So it's not my ignition i dont think.. the only thing left is the ground which will get changed tomorrow... Do i need to change both to the engine and to the starter? anything else it might be.. thanks....
That seems to say that either the large 12 volt cable to the starter is bad or the ground from battery to block is bad.
IF you checked the voltage from ignition wire to ground then the 12 volt from battery is probably bad. You check it by using meter from the large cable to starter and the other side to ground.
Good luck you are close
Hope it works out for you today
