4l60 ?
Old Jun 8, 2008 | 07:26 PM
fast414's Avatar
Default 4l60 ?
i like to drive my car a lot in the city and the highway but i need tranny that i can shift trough all the gears manual and the 4l60 in my 95 camaro, i don't have control of first gear. but i like the over drive so what is my best option. 350 400...... will it rev high on the highway . or is there way to have control of first gear in a 4l60...manual valve body. thanks
Old Jun 8, 2008 | 08:18 PM
ws6t3rror's Avatar
Programming will give you what you want easily, only other thing is if your car had 2.73 gears you will have to grind a little tab in the console off.
I cant imagine why you would want that, but its pretty easy to do.
Old Jun 8, 2008 | 08:43 PM
koolaid_kid's Avatar
Remove the console cover, you will see a little plastic tab that the shifter hits on to prevent it from going into first gear. Cut it off with a knife, and you will have a selectable first gear. Stealth first, I call it.
Old Jun 8, 2008 | 08:45 PM
Formula350's Avatar
And then after you cut it out, if you really want to see First, get the cover from a Camaro that shows it
BTW you have a 4L60E, not a 4L60. 93 is the only one that came with the non-electronic.
If you REALLY want manual shifting, get a manual valve body!
Old Jun 12, 2008 | 05:40 PM
SprayedZ's Avatar
Does anybody have a pic or any thing showing what to cut off i have always wanted to be able to hold first. So does anybody have any pics of what it is to cut off, i took the cover off and i dont see what you guys are talking about.
Old Jun 12, 2008 | 05:44 PM
96capricemgr's Avatar
Transgo kit helps manual control without having to go full manual.
Old Jun 12, 2008 | 08:12 PM
Formula350's Avatar
He's talking about the shifter cover so he can actually SELECT first. He has the one that only goes back to 2nd, so it'll shift out of first no matter what throttle %
Old Jun 13, 2008 | 01:23 PM
SprayedZ's Avatar
Yeah any pics???
Old Jun 13, 2008 | 02:13 PM
Next level's Avatar
its very easy....
just take apart your center console.....
ill get some pics up in a few, mine is already done tho and has been for 5 to 6 years now. Also, if you shift it too much you can kiss your tranny good bye.....
Old Jun 13, 2008 | 02:46 PM
djjab57's Avatar
This i have never understood mine has the 2:73's and has a 1st
Old Jun 13, 2008 | 03:13 PM
Formula350's Avatar
150 speedo and Z tires factory? If so that's why.
Old Jun 13, 2008 | 03:27 PM
djjab57's Avatar
Yes i have the 150 speedo The reason i said it cause i had read another thread that said all 2:73's were like that but i guess they were wrong
Old Jun 13, 2008 | 09:40 PM
Formula350's Avatar
I believe it's pretty directly related to the option package of having H rated tires and 110 speed (due to the H rating). But, don't hold me to that
Old Jun 14, 2008 | 12:40 PM
cruzin94's Avatar
but what do you do when you blow your tranny like i think i did today
Old Jun 14, 2008 | 02:21 PM
94 F-body's Avatar
every F-body car,(usually camaros and some Foumulas) usually only get the 150 speedo and a higer speed govner when they have factory Z rated tires, so I do believe it is related to the cars option package, cause I have not seen or heard of a TA or WS6 not having factory Z rated tires. Mine had factory goodies like those I have heard that it is a "safety" thing, due to the Z speed rating being up 149 and higher mph vs H being up to 130mph. See for yourself, http://www.discounttire.com/dtcs/infoSpeedRating.dos
Old Jun 14, 2008 | 11:03 PM
Formula350's Avatar
Yar, I know all dis Both my 91 and 93 had the uber-speedo thankfully
Uh, get it rebuilt? >_> That's what I'm doing, mine's pretty well gone too. 1st and 2nd are pretty good but 3rd and 4th slip pretty bad if I get it too much gas. If I ease into it they'll hold and climb the MPH still, thankfully. Which is all weird since 1-3 and 2-4 share bands, but 1 and 2 are fine and 3 and 4 are bad heh
