Motor R&R Video...
Great idea with the video... a suggestion if i may... reconsider doing it without the hoist...
not everyone has access or can afford to pay for one... although it may be the easiest way...
i have done it without the hoist (actually doing it again tonight) and it's not that bad... I use suv jackstands and a decent floor jack... i also have a small steel cart that i rest the tranny on to wheel it all around...
I saw your clip and I like the idea. I would like to see the finished version also, it would be a good refrence for 1st timers, and a reminder of where everything went for those who could not do it over night. It could be a a way to see where things go if you do little projects, so it might be an idea to have more than one verson. But that means alot of editing time, so maybe later down the line. If you really want to get in to it you could do the out from the bottem, out from the top and all in between, but that is only an idea. Too bad you could not get some help to get it out sooner.
4 guys to do that??? i do it alone and i leave the wheels on so it's not that hard to install the mounts into the shock tower braces (line the bolts up and let the car down on them... the 10% rule is in affect... you must be 10% smarter then the task at hand...)
I saw no details... i did see some fat guys a$$ crack ...
I've done it by myself also before, I just had a bunch of people over hanging out when we put it back together. I've done over thirty 4th gen swaps so I'm not new to the game. Usually the shock towers go back in easier, but I had the hals on the car with the coilovers raised up so that is why it was harder for it to go in this time.
I do like the cherry picker idea but i don't think i have enough room in the garage to roll the assembly out the side...
where and how did you hook up the cherry picker?
i would love to have the extra hands but everyone is always busy...
#32
i'm no expert... to each is own...
http://img.photobucket.com/albums/v2.../liftchain.jpg
We use these stands when we don't have enough space to pull the motor out the side...
http://img.photobucket.com/albums/v2...a/102_4672.jpg
#33
I used to wrap chains around the frame until we made these....
#35
Just letting you guys know that the project is still in motion. I will be receiving my stroker kit on Monday of next week and I should be able to finish by Friday of next week and have two videos.
1) Lt1 Motor R&R (F-Body)
2) How to Rebuild Your Ltx Motor
#40
the way i do it is....
disconnect everything,
power steering, brakes, drive shaft, the entire wiring harness, fuel, air conditioner, crossmember, abs wires, O2 sensors (anything else i've missed that has a wire/hose connected to engine)
note- disconnect front brakes lines from ABS and pull the lines out of the clips so they don't get bent/damaged
takes the nuts/bolts out for the strut tower (might have to take off the master cylinder to remove the torques bolts)
take off the wheels
loosen k-member bolts
drop the car down on a dolly making sure the k -member is positioned right under it
take out the k-member bolts and lift the car with an engine hoist or tree (i connected the engine hoist to the hood latch bracket and it held up just fine for both engine swaps i've done)
make sure nothing is still connected as you're slowly lifting the car
and bam you're done
take off the wheels
and bam you're done
