Is a EWP Really worth it??
Old Jun 13, 2008 | 05:26 PM
ulakovic22's Avatar
You can cut just the shroud and you can do it with a hacksaw or air tools (cut off wheel) if you have one. It's really not that much you have to take off.
Old Jun 13, 2008 | 05:39 PM
I8ASaleen's Avatar
Originally Posted by blackz6sp
There are ways to prevent that, warning light...
Amen brotha. I bought a relayed warning system from a very reputable dealer and it has a light to warn if the ground is failing or if the pump itself is about to poop out. Very well worth the investment. Also with a 160* t-stat, and a manual fan switch I can pretty much control how warm the engine gets whenever I like.
Old Jun 13, 2008 | 11:43 PM
Red93z28's Avatar
thanks alot guys keep the posts coming if you want, and yes im prob going to get a ewp, seeing as it is not my everday driver, also where can you get this relay switch to tell if the ewp is taking a **** on u?
Old Jun 14, 2008 | 09:09 PM
DarkKnightRider's Avatar
i just had my opti and waterpump replaced. got the old pump and am planning on converting it to an electric.
Old Apr 16, 2009 | 10:23 PM
sdotlog's Avatar
Where'd ya pick up the warning light relay system?
Old Apr 16, 2009 | 11:44 PM
Chitown's Avatar
Originally Posted by TDavanzo
I recently switched over to a CSR EWP and recommend the conversion. The reliability factor was something I considered because my car is a daily but I still chose to because the benefits are still there. There is risk with any part that it will fail sudden with damage as a result. If you wire it properly you can wire in fail-safes and warning systems to make it as pain-free as possible if it does fail.
Same here. I would not worry about it. I always check the temp gauge since I bought the car and it has not changed sine the ewp. I would do it.
Mine is a "everyother day" driver with slow rushour traffic for an hour. I have not had any problems that I didn't get from the mechanical pump, and i'm still on a 180.
Old Apr 17, 2009 | 05:06 AM
iceman15's Avatar
All I know is that if you monitor your gauges like you should frequently, you will be able to spot your temp gauge getting hotter (your EWP failing) and be able to pull over in time. I love my EWP as it frees up HP, I mean I have to deal with it in LA traffic and im still happy about its cooling capabilities. Its a definite worth it mod!
Old Apr 17, 2009 | 05:07 AM
iceman15's Avatar
Oh yea dont crap out on how you wire it. Get a painless EWP relay and call it a day. I mean if you want you can also get a warning light but its up to you.
Old Apr 17, 2009 | 08:59 AM
z_speedfreak's Avatar
Originally Posted by 96LT1355Z28
I 've got one and have not had any problems around town at the track or on the highway. I also have a 160 thermostat and the big *** Be Cool radiator. It's been on the car about a year now and no problems yet. I probaly shouldn't have said that!
what temp do you usually run at? I planned on swapping out my 160 for a 170tstat when I get an ewp fearing it would run too cool, right now it runs 175-180.
Old Apr 17, 2009 | 09:07 AM
joelster's Avatar
It's an excellent mod for the LT1 guys. The price alone should be it's best selling point. Have you seen what they charge for the LS1 guys? Yikes! In their case I would say no, but for us it's a no-brainer. If you decide to dive into the motor you can also swap out to a much better timing chain if you so wish to, since you no longer need that big geared piece.
Old Apr 17, 2009 | 11:57 AM
aboatguy's Avatar
I have a MEZ HD, been using it for years. NO PROBLEMS. As for the naysayers, I remember the same doom and gloom about electric coolling fans, and fuel pumps.
MIke
