AFR Headed guys, Spark plugs?
Here ya go. I have used this chart for my AFR heads for a long while. These are the gasket style plugs.
Heat range //////////////////////////// NGK ////////////////////////// Autolite
stock heat(5)10.5:1 compression n/a...2382 ..............................AR3937
1 cold (6) 11.5:1 compression n/a.....5553 (BKR6E)...................AR3936
2 cold (7) 12.5:1 compression n/a.....4091..............................AR3935
3 cold (8) 150 shot.........................4554 (R5671A-8)..............AR3934
4 cold (9) 150-250 shot..................5238 (R5671A-9)...............AR3933
5 cold (10) 300 shot........................5820 (R5671A-10).............AR3932
6 cold (11) 350+shot.........................?................ .................. AR3931
I have been around 12.5:1 compression so I would use a 7 for n/a then colder per size shot I used. You guys with less compression need to scale back one size or two.....meaning if you are 10.5:1 compression use the 5 heat range for n/a and a 6 or 7 for nitrous.....etc.
Good luck!
Good luck!
Good luck!
Good luck!
Reviving this old thread
I pulled TR6's out of my AFR heads - shop put them in and they should have used gasket-ed!
AFR says to start with 3910's but should I really just put in 3937?
I have a about 350-400HP NA.
Need to buy plugs for this weekend so is it 3910 cold-*** from AFR website, or 3937 like you guys say?
#32
Ok one more question
does it matter taper or gasket - on how the head is cut? AFR said it doesn't matter if the head is cut flat or taper, that either gasket or taper plug will fit.
I'm so confused.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I'm going to go look at the head now and see what the plug hole looks like.
I'm so confused.
#35
Well that would shroud the plug, given of course without looking at one installed that it is set back deeper in the hole (or shallower in this case...lol)
