awsome cc503 dyno today
Old Jun 27, 2008 | 06:17 PM
  #41
MadMike 97 Z28's Avatar
Originally Posted by the_merv
You have a good setup..but something is definately wrong somewhere..your Torque curve drops where it should peak. I think it was a mis-read on one of the Sensors for the Dyno.
Quite a few of us here build our own Engines and are running them, myself included.
Mine Dyno'd 412/390 at the wheels and ran a 11.19 at the Track..by far I Dyno'd alot lower than the Engine has, but my curve looked more normal..well closer to what most people's have.
I would say if you want to call people out to learn how to build an Engine..a retard can take a wrench and assemble and Engine. It takes the brains and the skill to understand how everything works. Compare your HP to TQ numbers..something is definately off, I'm putting my money on the Dyno. If that part of it's messing up, you will get some interesting readings.
My first pull got me 404hp, like 17billion Torque. If I had that much it would of broke the Dyno and the shockwave of that explosion would've dropped every girls panties within a 5-mile radius.
Calm it down a little bro..
Old Jun 27, 2008 | 06:45 PM
  #42
the_merv's Avatar
Veteran: Air Force
Originally Posted by MadMike 97 Z28
Old Jun 27, 2008 | 08:36 PM
  #43
transam1577's Avatar
ok so tofay i took everyone advise and got on a dyno jet and i put down 367rwhp & 416.8rwtq so i still believe my dynos are accurate (only thing i did was fix exhaust leak) so the numbers are right. but i will keep you guys posted on my dyno after injectors and tune ALso my track video will be posted when i finnally go. and sorry if i came off as a dick on my last couple of posts but just trying to let everyone know im not lying. like i said it pulls harded than i even thought it would but it is what it is...
Old Jun 27, 2008 | 10:16 PM
  #44
Puck's Avatar
Teach me how to do that.
Old Jun 27, 2008 | 10:24 PM
  #45
the_merv's Avatar
Veteran: Air Force
It will take many years of training and conditioning..
Old Jun 27, 2008 | 11:27 PM
  #46
infinitebird's Avatar
I would stop dynoing your car until you get the injectors/tune. You're going WAY lean on that dyno sheet in the high 5k range when you max the injectors.
Old Jun 28, 2008 | 02:15 PM
  #47
I8ASaleen's Avatar
Yea, say hello detonation.
Old Jul 2, 2008 | 02:12 PM
  #48
Purple95Z28's Avatar
417ft lbs at the wheels from an N/A 350... no frickin' way
Old Jul 2, 2008 | 03:06 PM
  #49
Schweet97Z's Avatar
Get a new dyno/tuner
Im running stock injectors on a LE2/GM-847 setup and its making power all the way to 6800 and not going lean.
Old Jul 2, 2008 | 03:46 PM
  #50
I'm assuming you boosted the fuel pressure or something?
stock injectors are not going to work with that without some serious modification.
Old Jul 2, 2008 | 04:24 PM
  #51
Schweet97Z's Avatar
The only thing im running is a 255lph Pump. Ive seen plenty of people run stock injectors w/ heads/cam setup and have a flat air/fuel curve. Im not sayin it wouldnt hurt for a bigger set, and im not sayin there isnt a few ponies to be gained, all that im sayin is there is something wrong with this guys setup....I dont feel the numbers are true. That torque number is awful high for a stock cubic inch motor. And by changing injectors that he isnt going to gain 50 whp.
Old Jul 2, 2008 | 04:42 PM
  #52
It all depends on the car/setup though and the condition things are in. If the injectors are old/worn out, etc they are not going to work as well. On my 94 car I did a scan and at high 5k rpms my stockers were at 90% dc at a near stock power level. If I had done heads and cam and left them untouched, they would have been way maxed out.
On the other hand some people find the stockers work up to 400rwhp or so, and that's generally considered to be their theoretical limit.
I agree he's not going to gain 50 hp by changing the injectors, and I already said there's no way he will get close to 400 with that cam anyway. But it's clear his car is not running right from that dyno sheet. Since he has stock injectors with no tuning, I'd be willing to bet that is the problem.
Old Jul 2, 2008 | 04:43 PM
  #53
slick1851's Avatar
Originally Posted by myltwon
high 300's low 400's aren't impossible, but thats with a good tune, healthy compression and well worked heads
In La La Land.........Ill belive it when somone does it, until that its not going to happen
Old Jul 2, 2008 | 04:45 PM
  #54
slick1851's Avatar
Amen to that! To many people on here are idiots and live in dream LT1 world
  #55
sorry, but there's just no way you are getting 400rwhp out of the 503 cam.
Old Jul 2, 2008 | 08:47 PM
  #56
LOL LOL i havent been on here in a while so i havent seen all the bull s--- that you guys are saying now i understand why you guys think what you think but whit till you see my timeslip at the track!!! or better yet anyone nearby is welcome to come!!! but you will see a car that performs way better than way better N/A than your slapped together bulls---... i hate to sound like a dick but im not new to this i do have a two 10 sec big block drag trucks aswell and i know how they perform so i can compare.and i dynoed my car on two diff. dynos and the are consistint, but i dont know maybe when the companys thats bought those 80K dollar dynos got some bad ones (thats ironic as hell) i will get the injectors and tune soon but untill then im done debating with you on what i know!!!!!!!
Old Jul 3, 2008 | 11:29 AM
  #57
no one said your car couldn't be fast. You don't need huge dyno numbers to run well at the track. I'm sure everyone here knows that. I just don't think you are going to get 400rwhp, that's all.
Old Jul 3, 2008 | 11:52 AM
  #58
Schweet97Z's Avatar
its fine...lets just sit back, relax and then tell him "I TOLD YA SO!"
  #59
If you can find some dyno graphs of other other N/A 350s making almost 420ft lbs at the wheels then maybe people will believe the numbers.
Old Jul 3, 2008 | 11:58 AM
  #60
Vicious95Z28's Avatar
450 rwhp from a cc305. Sorry not gonna happen, not without some spray or a blower. It's just not there, even with the best heads and tune.
With some good ported heads and supporting tune, honestly I would feel like a lucky dog to get 410-415 with the cam that I have.
