awsome cc503 dyno today
Old Jun 23, 2008 | 06:02 PM
transam1577's Avatar
Default awsome cc503 dyno today
i finally fixed my being advanced prob. (opti bad) so dynoed it today it is the car in my sig the only thing ive added since sig. is lt4 KM!! and keep in mind this is on a bone stock tune!!!! through stock heads i P&P myself there flow #s where 270ish/210ish. ohh and cc503 cam, but anyways i decided to get a before and after tune dyno. so i did the pull and cam up with 360.1 rwhp at5131rpm ,402.6 rwtq at 3124rpm, and its not tuned and i have a big exhaust leaks at egr pipe. i ran it up to 6200 rpm but at 5100rpm it started loseing power fast must be from stock injectors i guess or tune? ohh and this is a mustang dyno i am very happy i am hoping to be 450hp 450 tq ish when injectors and tune.!!! my heads are obviously pretty awsome so i aM VERY HAPPY!!! any thoughts GUYS on why it lost power at 5100 rpm?
Old Jun 23, 2008 | 06:11 PM
Formula350's Avatar
Helps to HAVE a sig haha
Old Jun 23, 2008 | 06:13 PM
HoLLo's Avatar
Sweet. That's the cam I want to get.
Old Jun 23, 2008 | 06:16 PM
oh sorry i thought i did my bad its a brand new stock bottom end, cc503,1.6 pro mag rr,stock 94 heads p&p by me flowed 270ish/210ish,ported intake,LTs pacesetter, flowmaster exhaust,lt4 KM,ram air,M6(on stock tune) stock injectors
Old Jun 23, 2008 | 06:47 PM
C5042081's Avatar
good #'s , you have some pretty decent flowing heads
Old Jun 23, 2008 | 09:36 PM
I8ASaleen's Avatar
Stock injectors
Old Jun 23, 2008 | 11:07 PM
i know but i dont know what size injectors to go with any thoughts?
Old Jun 23, 2008 | 11:10 PM
96lt1m6's Avatar
racetronix 32.2
Old Jun 23, 2008 | 11:27 PM
32lbs are those big enough? i was thinking 36-42lbs
Old Jun 23, 2008 | 11:46 PM
fergymoto's Avatar
Yeah they are big enough. I ran 30lb SVOs with my LPE heads/cam setup.
Old Jun 24, 2008 | 12:20 AM
bad99transam's Avatar
good numbers
Old Jun 24, 2008 | 12:26 AM
infinitebird's Avatar
why you are losing power?
1. stock injectors
2. big exhaust leak
3. untuned
seems like you answered your own question lol
and no there is no way you are going to hit 450rw with that setup even if its working right.
Old Jun 24, 2008 | 12:34 AM
then what do you think i will hit
Old Jun 24, 2008 | 12:41 AM
Toronto_LT1's Avatar
stock cubes??
Old Jun 24, 2008 | 01:17 AM
you will be lucky to get anywhere close to 400 with that cam, I will guess 385.
Old Jun 24, 2008 | 10:40 AM
myltwon's Avatar
high 300's low 400's aren't impossible, but thats with a good tune, healthy compression and well worked heads
Old Jun 24, 2008 | 10:41 AM
myltwon's Avatar
also my cc503 cam only car was still making power at 6,400rpm but then again that was with stock heads, not sure how the cam pulls with worked ones
Old Jun 24, 2008 | 04:16 PM
bricez28's Avatar
wow thats basically the set up i want, sounds like good numbers!
Old Jun 24, 2008 | 04:20 PM
Purple95Z28's Avatar
That is a crazy high torque number for a 350/355.
Old Jun 24, 2008 | 07:04 PM
i know especcially untuned and keep in mind i have a big exhaust leak
ran out of injector at 5100 and the cc503 with my heads should pull 6300-6500rpm plenty of horses to be mad there but i will post the dyno sheet asap
