anyone else have ticking at hot idle?
ever since i put the headers in ive noticed a ticking that sounds mechanical, but goes away after 1200rpm or so. itll tick when the engine warms up, even at 40psi of oil pressure.
i just replaced the gaskets with carbon xxx ones, and my bandclamps have copper sealant all over them on the inside. compared to my dad's 4.8 and LS engines my engine sounds kind of loud on idle. plugs are tight, EGR tube has a new gasket on it, unless that could be the problem i dont know of any exhaust leaks there could be.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
One easy way to find out if it's an exhaust leak is while moving, put your car in a high gear that will put a good load on the engine and press down on the gas pedal. If it's an auto, just stab the gas at a low speed. If the tick gets louder then it's an exhaust leak. If not then it's mechanical.
well my old MLS gaskets blew out 1 week after i did the LTs.
its a weird thing, itll go away when you rev it anything above the set idle speed.
id say after 1-2 min from cold start itll tick and from then on itll still do it.
ok i checked the lash, and went through them and turned the nuts 1/8th of a turn since the pushrods didnt move up or down, but spun easy as hell, and i still have the ticking. i bought a stethoscope, and it sounds pretty good under the VCs, but in the passenger rear of the intake manifold you can hear a louder tick than normal and is consistant with the ticking i hear coming from under the car. looks like LS7 lifters are in my future
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
To my experience, all cars with headers have a "ringing" or "ticking" sound, as they don't deaden the sound of the exhaust pulses as well as cast iron manifolds.
If your rockers are properly adjusted, and you're not hearing the lifers "tick", you're probably just hearing the headers. Leaking header gaskets seem to have more of a "whoosh", if that's an accurate way to describe the sound....
im gonna take 2 videos 1 of it quiet at cold start and one of the ticking. its more pronounced then the exhaust pulses, seems like its only coming from the passenger side.
Mine has a light ticking. I think its normal when you have headers they are alot thinner than the stock manifolds so the valve train noise is easier to hear. Just my OP.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
ok heres video 1. its that choppy ticking you hear. this is the best area i can hear it, and the loudest from the sound deflecting off of the wood.
oh yea and im on my girlfriend's youtube account dont mind the name![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
http://www.youtube.com/watch?v=W1Nj8fbSCtY
under the front
http://www.youtube.com/watch?v=u29Gzzk9USU&feature=user
under the front
