LT1 cluster question.
Old Jul 12, 2008 | 02:17 AM
Runamuck's Avatar
Default LT1 cluster question.
if you have a 96 car, is the only year cluster you can replace from 96.
does the OBD2 really have anything to do with the cluster since they are the same from 93-96?
i need a 96 firebird/ Trans am cluster, and it seem its hard to find that specific year.
i need to know if any year fill fit, and wether the OBD1 cluster has any difference from the 2.
Old Jul 12, 2008 | 04:29 AM
96lt1m6's Avatar
they interchange.
Old Jul 12, 2008 | 05:48 AM
infinitebird's Avatar
any 94-96 cluster will work. 93 and 97 are different.
Old Jul 12, 2008 | 10:46 AM
Runamuck's Avatar
is there any real difference as far as plug and play value with the V6 cluster?
is it just the RPM difference and speed?
Old Jul 12, 2008 | 11:07 AM
I8ASaleen's Avatar
Yea, the V6 cluster only goes up to 120, while most of the V8 ones go up to 150.
Old Jul 12, 2008 | 11:38 AM
fergymoto's Avatar
The tach in a V6 cluster uses a different signal than the V8 ones. If you use a V6 cluster the tach is going to read a fair amount higher than what the engine is really turning.
