AI cam
Old Jul 12, 2008 | 03:34 PM
black95z28's Avatar
Default AI cam
I have a 95 LT1 with headers, exhaust, cai, and a 3200 stall. I am considering the ai 226/234 540/575 and a 110 LSA cam kit. I know i will also have to purchase new lifters (LS7) and probably an LT4 timing chain. My question is does this cam make good usable power on stock heads? I am goin to do heads eventually but not at the same time. Also will i need a new oil pump?
black95z28's Avatar
I appreciate any input.
Thanks
Old Jul 12, 2008 | 03:38 PM
black95z28's Avatar
also where is the best place to have it tuned?
Old Jul 12, 2008 | 03:44 PM
slick1851's Avatar
call ai
Old Jul 12, 2008 | 04:01 PM
96capricemgr's Avatar
No need to buy new lifters, you can if you want but generally it is not mandatory. On the timing chain I would just get a new stock chain and put it on the old gears provided they look OK.
You were looking at the full kit right? Springs, pushrods, rockers etc., the stuff you actually do need.
Would not bother replacing the oilpump, would put a melling driveshaft in they are only like $7 cheap insurance. Might consider a higher pressure relief spring in the pump they are cheap too.
Melling IS-55E
spring is GMPP 3848911
Old Jul 12, 2008 | 10:37 PM
Pony_Killer's Avatar
That 226/234 kit is what I bought tuesday i can't wait till everything gets here! Call them I talked to Ron he's a good guy!
Old Jul 13, 2008 | 11:50 AM
black95z28's Avatar
yes i was looking at the complete kit which includes new pushrods, gaskets, rocker arms, valve springs, retainers, lockers, and seals etc.
Old Jul 13, 2008 | 12:06 PM
kyle88transam's Avatar
I ordered the same kit. It should be here tomorrow.
Old Jul 13, 2008 | 12:14 PM
Tireburnin's Avatar
I was going to order a cam, but instead I ordered a crate motor. Can't wait to get it in the car.
Old Jul 13, 2008 | 12:43 PM
StealthFormula's Avatar
Thats a nice cam to run on stock heads. So you know, an LT4 timing chain WILL NOT fit on LT1 sprockets. I made that stupid mistake myself way back so just get a new GM LT1 chain for $40 assuming the sprockets are in good shape as well.
Old Jul 13, 2008 | 07:31 PM
black95z28's Avatar
I didnt know that stealth, thanks.
Old Jul 13, 2008 | 11:26 PM
GIVE EM' THE BIRD's Avatar
how much is that ai kit. and does it come with springs and rockers.
Old Jul 14, 2008 | 05:41 PM
They offer the most complete kit I have seen to date for an LT1 cam swap. Right down to new valve seals and installation tool.
Old Jul 14, 2008 | 07:37 PM
That y I went with him I wasn't sure what all I was needing to do this cam install and this has everything u will need!! Plus I saved almost 250 bucks not buying everything seprate from everybody else..now if it would hurry up n get here I've ran out of stuff to clean and paint under the hood!
Old Jul 14, 2008 | 08:03 PM
im interested in the cam the ts mentioned. would it be necessarry to run different valvesprings even though im not planning on 1.6 rr's.
Old Jul 14, 2008 | 08:22 PM
The stock cam can benifit from more spring. In other words ALL upgrade cams need more than stock valvesprings. I know that in decades pas with flat tappets sometimes you could get away with stock springs, but with the heavier roller lifters and more aggressive lobes, there is no chance.
