4 bolt LT1
Old Jul 14, 2008 | 08:15 PM
irocchenault's Avatar
Default 4 bolt LT1
right now i have a stock lt1. any idea on how much it would cost and where to look or go to have it converted to a 4 bolt main. ive never heard a story of the stock 2 bolt go bad even at the dragstrip with 800 ponies. but still. any input whatsoever
Old Jul 15, 2008 | 07:05 AM
n2ocamaro's Avatar
Do you mean a totally stock motor or just stock short block. Either way, I wouldn't worry about it till you do a rebuild. You will need to have the block bare to have it done and if your taking it apart down to the block you might as well do a rebuild. You have to have it done at a machine shop. Prices vary. I did splayed 4 bolt caps and I paid $300.00 for machining and $200.00 the caps.
Old Jul 15, 2008 | 12:10 PM
yeah it's a totally stock motor still running in the car
Old Jul 15, 2008 | 02:53 PM
Captainofiron's Avatar
what year is the engine?
if its a 97 you might be a lucky one that got a leftover vette block.
my LT1 is a factory 4bolt
Old Jul 15, 2008 | 04:20 PM
it's a 96 z. stock 2 bolt.
Old Jul 15, 2008 | 10:14 PM
smooveZ's Avatar
When my stock block developed a piston slap at 30,000 miles my extended warranty was still good so GM replaced the motor. I heard they replaced it with a 4 bolt block.
Old Jul 15, 2008 | 10:56 PM
I have heard that too
Old Jul 16, 2008 | 06:19 PM
cnorton's Avatar
That's a very reasonable price. The last conversion I had done cost about $750 by the time I got it back. Believe me, 800 or even 600 horsepower is pushing your luck. If you disassemble a few of these puppies that have seen 75 or a hundred passes at 7000 RPM, you'll see evidence of cap walk with 2-bolt mains. From that point to disaster is only a short step.
c
Old Jul 17, 2008 | 08:50 AM
FlamingChicken's Avatar
that is a good deal. machine work only on mine was 750. thats drill/tap and align bore/hone. forget how much the 3 caps were but they were pro-gram splayed caps.
Old Jul 17, 2008 | 12:37 PM
Smokeshow_2006's Avatar
while we're on the subject, Im going to hijack a bit.
Assuming ive got a 4 bolt small block with forged rotating assembly laying around, would it be pheasable to take all the lt1 gear, and place it on the 4 bolt block without a crap load of extra work?
Old Jul 17, 2008 | 01:05 PM
96capricemgr's Avatar
The LT1 and gen 1 blocks, while they share basic architecture are not interchangeable.
Far as 4-bolt mains, by the time you actually need them you are better off with aftermarket caps than OEM and there is still a fair amount of machining to change the caps, so don't pretend factory 4-bolt is anything wonderful.
