LT1 Programmer
Old Jul 15, 2008 | 05:02 PM
irocchenault's Avatar
Default LT1 Programmer
Is there a good programmer for the LT1 for a new cam and heads so you can tune it properly instead of some hypertech ****. i can't find any.
Old Jul 15, 2008 | 05:09 PM
96lt1m6's Avatar
madtuner,pcm4less etc.
will be able to handle your request
hand held equipment that works does not exist
Old Jul 15, 2008 | 05:15 PM
DAVE00's Avatar
PCMforless as Bryan is an awesome tuner. You will see wayyyy more gains and customization than the handheld programer. Do a seach and you will find ton's of stuff abou them all.
Old Jul 15, 2008 | 06:04 PM
96capricemgr's Avatar
It would help a whole lot if you told us what you have, even just assuming it is an LT1 f-body there are three different systems it could be using depending on what exact year it is.
Old Jul 15, 2008 | 09:28 PM
so pretty much the only way to tune is to exchange your pcm or to send it in and tell them what you have so they can tune it. is there a program for a computer that lets you do it at home. a full on tune program. not a hypertech. or is sending in mine pretty much the only option.
Old Jul 15, 2008 | 09:32 PM
There absolutely are ways of doing it at home, but we can't give you more info till you tell us what you have?
Old Jul 15, 2008 | 10:33 PM
i have a 96 z28
Old Jul 15, 2008 | 10:48 PM
lt1noob's Avatar
send it in or get it dyno tuned.
Old Jul 16, 2008 | 05:17 AM
96 is a little more expensive to tune than a 94-5 but you can still do it at home, or if you don't have to worry about emissions testing you can swap to a 94-5 computer, cheaper software and a few of the professional tuners say a little more power.
Tunercat is my pick on software.
Old Jul 16, 2008 | 06:12 AM
koolaid_kid's Avatar
A 96 is OBDII, so you could use TunerCat or LT1Edit. I would select TunerCat, as it is more flexible. It is currently marketed by Jet, and can be found in several places. You also need scanner software, and a wideband O2, such as an LM1, and a laptop computer.
Old Jul 16, 2008 | 07:35 AM
harner's Avatar
You don't necessarily need to send the computer in to get it done, although its the easiest choice. I had my tune emailed to me and then uploaded it with my laptop. All I had to buy was an ALDL obd1 cable since my car is a '94 and it cut down on travel time. If I had to do it over again I would have shipped it. The damn cable was over $50 i think.
Old Jul 16, 2008 | 08:37 AM
LT1 TRANSAM's Avatar
If anyone is intrested i have a 1996 computer and a Hypertech 11 Programmer i need to get rid of,i would make someone a good deal on .I'm changing over to a 350 turbo tranny along with 383 so i cant use this stuff.
Old Jul 16, 2008 | 02:27 PM
im lookin for a program i can load onto my computer that comes with the OBDII cable so i can tune myself. is there any company that can sell me a program
Old Jul 16, 2008 | 03:50 PM
The programmer has a cable and a hand held to program your car ,it lets you set your shift points,thermastat from 180 to 160,reset your speedo if you change gears or tire size,set your rev limiter,and tune it for a bit more power 15-20 more hp and i got 22mpg and my TA is black on black hard top.
Old Jul 16, 2008 | 04:27 PM
that programmer is ****. i want one that can fully customize my pcm
Old Jul 16, 2008 | 06:03 PM
IllusionalTA's Avatar
http://www.streetperformance.com/par...rum-tuner.html
We use this product at Kaltech in NY.. Really nice program... Get's the job done nicely for OBDII Car's..
Old Jul 16, 2008 | 10:25 PM
hey IllusinalTA.....
is this programmer a no **** install and plug in and tune yourself pretty much every single perammiter you can possibly imagine. cause that would be amazing.
Old Jul 17, 2008 | 05:44 AM
hey i was just telling you about that programmer but f#@k you with that remark.
Old Jul 17, 2008 | 06:51 AM
I just used it on a 96 IMpala, that was mis tuned by mail order.. Worked great and has more than enough parameter's to do whatever you need... Easy to use interface, nice GUI.. etc...
Btw be nice to those that give you info... They're all just trying to help...
Old Jul 17, 2008 | 11:07 AM
This is the TunerCat programmer, which I mentioned previously. It is the best you can get for your car, and yes, it is quite flexible.
