puttin in a tranny cooler
Old Jul 19, 2008 | 03:33 PM
cruzin94's Avatar
Default puttin in a tranny cooler
i need to kno which line off the transmission in the feed and which is the return because im puttin in a tranny cooler, and dose every one go from the cooler to the radiator or do you just use the cooler?
Old Jul 19, 2008 | 03:44 PM
Badazz 97 TA's Avatar
you can do it it either way. you can bypass the radiator or go through it. its up to you. the trans line that screws into the radiator (on the bottom passenger side of radiator) is the "in line" and then the other one is the return.
Old Jul 19, 2008 | 06:43 PM
the_merv's Avatar
Most coolers the direction doesn't matter..I have a B&M Super Cooler.. I completely bypassed the Radiator.
Old Jul 20, 2008 | 12:00 PM
Stroked96Bowtie's Avatar
Mine goes through the radiator then through the cooler...cant hurt to have 2 cooling points. Especially if you have a high stall convertor, these transmissions can build alot of heat. My last 4l60e will vouch for that
Old Jul 20, 2008 | 12:21 PM
grn95t/a's Avatar
i ran mine into the rad first then into the b&m stacked plate cooler second then back to the trans
**taken from the transmision section**
4L60/4L60E/4L65E
Fitting Location Thread Size Flow Direction
Upper ¼" Pipe Return/in
Lower ¼" Pipe Cooler feed/out
Old Jul 20, 2008 | 05:07 PM
01Z28M6's Avatar
It's the top line on the transmission that is the return. I don't think you will have better cooling if you bypass the radiator. If you can search you will find quite a few threads to verify.
Old Jul 21, 2008 | 02:23 PM
the_merv's Avatar
I have an extra B&M Super Cooler FS if anyone needs one..
Old Jul 21, 2008 | 03:43 PM
Crows93Z's Avatar
Here's a step by step install on an LT1 from bret franker's page. Why bypass the stock cooler? you'll just keep your trans even cooler, and it's almost like a plug and play situation with the stock cooler still there.
http://www.bfranker.badz28.com/94z/trannycooler.htm
Old Jul 21, 2008 | 09:01 PM
cruzin94's Avatar
so should i bypass the radiator or not it dose make sense becasue the radiator is hot that it would heat up the tranny oil but on the other hand is dose have air rushin thru is so yes or no on bypassin the radiator??
Old Jul 22, 2008 | 10:01 AM
Crows93Z's Avatar
don't bypass the radiator. yoiu have a stock tranny cooler that will offer up to 30% more cooling in addition to the auxiliary trans cooler. why would you pass that up. it's much easier to go in line with the stock cooler too. it's all on the link i just posted. look at that and follow it. the guy knows what he's talking about.
