Left-side Rich Condition - Please Help!!!
New Spark plugs (NGK's)
Checked, Double and Triple checked for exhaust leaks and can't find any
pulled fuel rail to pressure check injectors for a leaky one - NOPE
checked all vacuum fittings and no apparent leaks/cracked hoses
New O2's installed
Plug wires checked an all fine
Really not figuring out what is going on here, can someone let me know what could cause this and make some suggestions as to where I can look. I have been working with Bryan at PCMforless on my tune and he is tweaking it to lean it out a little to accommodate for the rich issue, but I want to solve the main issue to fix it for good. PS - No codes are being thrown as well.
FYI - Here is a list of my mods so you know what is going on:
383 - Eagle Stroke Kit
CC305 cam
SVO 30# inj
All Air and EGR are still present for emissions purposes
LT4 KM
ETC...
Thanks for your input and advise.
either the tune is jacked up or maybe something is off with spark on that side?
check the basics and make sure you have spark at each cylinder.
are there aftermarket fuel rails or modding the cross over tube that will resurt in more equal pressure?
If the BLM is staying near 108 on only one side, then there is clearly a problem.
Pampered-Z...you can fix the problem but again its usually not necessary until you get into high hp cars, 90% of LT1's and LS1's are still like this, but if you want you can always make a parallel system, you will need some aftermarket fuel rails, a y block from the feed line, then an aftermarket FPR, and then another Y to the return line. Its a simple concept but if you've ever looked into AN lines and fittings you know this **** can add up quickly, so expect to spend atleast $500, and thats if you're keeping the stock feed lines. If you truly need this then you'll need a full AN setup which will probably run you atleast $1500 for the pump, the fittings, the lines, the rails, the regulator, and all the other small stuff that adds up.
My dr side is near perfect, but pass is rich, real rich.
Doesn't run bad or anything, but datamaster shows to be very rich...
Looking for a solution as well..
-Rick
