Rod swap/install writeup?
Old Jul 25, 2008 | 01:23 AM
LSWHO's Avatar
Default Rod swap/install writeup?
Is there a good one? I know it's the worst part of our bottom end, and I have no clue as to how to start this kinda thing. Never touched the bottom end before, unless you count a cam, which I wouldn't.
Old Jul 25, 2008 | 10:19 AM
LM97Z's Avatar
The machineing is key, the crank needs to be spot-on, the block also (crank allignment) along with the bore, good quality rods/bolts are what your after, if you've never worked on a short block, get some good chevy rebuild books & start reading , familiarize yourself with things, the machine shop will set them up as for checking balance/straightness & any reconditioning if needed, plus installing the bolts & pistons, even though there a new set, they still need to be checked, if its a street car, i would stay away from an aluminum rod, they have less life cycle, just get a good "lighter" forged rod with wave-lock bolts.
Old Jul 25, 2008 | 10:42 AM
LSWHO's Avatar
How much of the motor needs to be pulled off?
Old Jul 25, 2008 | 10:51 AM
connexion2005's Avatar
You have to pull the motor. I'm working on the full video man just you wait...
https://ls1tech.com/forums/showthrea...=935163&page=2
Old Jul 25, 2008 | 11:00 AM
LSWHO's Avatar
That's awesome, man! I can't wait to see it. Finally a video like that for a car I actually own!
Old Jul 25, 2008 | 11:23 AM
No problem man. It will be featured on my set www.ls1videohowto.com
Old Jul 25, 2008 | 01:37 PM
PNYKLR-TA's Avatar
sweet i'm definitely interested in doing this as well. and lswho, i can't remember exactly but i'm almost sure you said something about being in the phoenix area. if you are i am also and would be willing to help ya out cause id love to do this to my motor at some point in time as well.
Old Jul 25, 2008 | 05:02 PM
LSWHO's Avatar
Well it won't be anytime soon. I can't even think of planning something like this without knowing what I'd be getting into. Thanks though. It is something I will eventually do, unless I find that it is something I can easily do. I thought a cam install was decently easy, so who knows.
Old Jul 25, 2008 | 05:55 PM
96capricemgr's Avatar
changing stock rods is not something you can do at home. It is part of a rebuild.
