Rebuild a 4l60e or Buy?
Old Jul 27, 2008 | 08:21 PM
1MeanGreenZ28's Avatar
Default Rebuild a 4l60e or Buy?
I have a '96 z28 Camaro with 147,000 miles on it. Im pretty sure the tranny does as well. A little bolt came loose and got wedged in between the bell housing and the converter. It busted a piece out of the casing of the tranny and caused it to crack. It does leak a little tranny fluid but still shifts fine. I was wandering where this bolt came from? Also, I want to buy a 3600 Vig stall to put in it. Should I go ahead and buy the stall and weld up the crack? Do you recommend putting in a rebuild kit? If so what kind? OR Should I buy a new tranny? If so what kind of tranny do you recommend? I want to stay in between $1000 to $1500 dollar range if possible. Sorry for all the questions but just wanting to make the right choice. Please, any suggestions would be great. Thanks!
Old Jul 28, 2008 | 12:11 PM
TABBED 5.3's Avatar
i had the same issue in my car, however the crack in the bellhousing was there when i bought it. i would NOT reccomend putting a stall in there until you a get a new transmission. You might try welding it but you can find used stock 4l60e for around 300 bucks. thats what i did, then put the stall in. Of course you could always go with one of the vendors you should be able to get a stout 4l60e for about 1500 from them.
Old Jul 28, 2008 | 01:57 PM
WHITEBOY_ZACH's Avatar
idk how reputable they are but i found a 4l60e that will hold 800 hp for 1450 on ebay with 2 year unlimited warranty
Old Jul 28, 2008 | 04:46 PM
Come on guys keep the suggestions and opinions coming! I want to here more! Thanks.
Old Jul 28, 2008 | 04:50 PM
Next level's Avatar
TH400, alittle bit more money but worth it. Wont break, cant race on it, and ready to go. If you want a 4 speed go with the TH350
Old Jul 28, 2008 | 06:56 PM
juanito's Avatar
i went with PERFORMABUILT LVL2 for $1650 . rated to about 700hp. theres a lvl 1 also for a bit cheaper. no core needed and free ship. do some research. but dont get a stall that high withough having your tranny built to handle it. but if you do... be shure to get a tranny cooler.
Old Jul 28, 2008 | 10:09 PM
Bad_tx_Z28's Avatar
X2 for performabuilt. check them out in the Auto tranny forum..
Old Jul 28, 2008 | 10:43 PM
I was checking them out earlier and they seem to be pretty good. Should I go ahead a spend the money for the stage 2 tranny? Do they have a core charge fee? I couldnt find that on the website.
Old Jul 29, 2008 | 03:29 PM
juanito's Avatar
they dont have a core charge fee. i believe if you want they will take your core and give you 75 buks. all their prices are shipped and include a tranny cooler also.
i went ahead and spent the extra for the level 2 . just incase i decide to hit above 500hp i know the tranny will hold up!.
Old Jul 29, 2008 | 03:56 PM
What kind of stall are you going to be running? The brand?
Old Jul 29, 2008 | 04:35 PM
juanito's Avatar
performabuilt 3k stall.
they had a sale going on when i put it on lay away( oh yeah they do that) and i got the combo (lvl2 tranny plus 9" 3k stall) for $2050 . i believe they have a sale still going on .
https://ls1tech.com/forums/showthrea...=951570&page=2
