Motor out the top
Here's the easiest way to pull it out the top. remove hood, radiator and all front hoses, etc. remove alternator, disconnect tranny, no power steering pump, smog pump, etc. Put all that crap on later..... Turn motor 90 degrees in the engine bay so the front is aimed toward the drivers side. Get motor low enough in the bay so that the valvetrain clears the cowl then start rotating motor back to straight..... works everytime. Lose the valve covers as well cuz they'll hit and if they are nice you'll jack your **** up....
here's a few shots of us doing mine from the top.....
Thanks for the pictures, I guess I will look into getting one, although I guess I will have to fix that bolt, or I can go the remove intake route I suppose. No rush here though, still don't have clutch money, being unemployed sucks. Sunday I will probably try to get the last two bolts out for motor to bellhousing, if its not raining, 40-50% all on the 5 day forecast, in FL that means its going to rain.
Got around to working on it today and got the accessory bracket and a/c out today, but can't seem to get those two bolts out. I can barely get the wrench on the middle one, and don't seem to have any room to turn it, so I'm perplexed. Between those two bolts, and one in each motor mount and the oil cooler, it should be ready to come out.
ive done it both ways out the top and bottom. I prefer doing it out the top. Once you do it both ways youll know which way you like better.
http://www.akmcables.com/l99.htm
That's an iron headed motor. Suspended by 4 fuel rail bolts. If I hadn't done it myself several times, I wouldn't trust it either.
BUt it works great. Note the hood is still on the car.
And yeah, 2-3 feet of socket extensions with wobbles will get to those bolts. Nobody said it was easy!
I pulled off all the accesories. Leave the manifolds on.
Take off the wheels in the front.
Take off the struts.
Take off Upper A arms.
2 bolts and a small bolt take out the power steering rack.(Dont forget your hoses too!)
Take off the Hubs/Spindle assembly.
6 bolts take off the front subframe.(Becareful about power steering/brake lines)
[[At this point youll need to hold the engine up, id attach a hoist, thats what i did]]
Take off the torque arm if you didnt
Then the driveshaft
3 or 4 bolts take off the trans xmember
At this point brace the back of the trans with a jack so it doesnt come crashing down
Set something like a dolly or something under the trans/motor assy
lower the two in sync onto the dolly
as it is coming down just check to make sure your not pulling any wires or hoses
disconnect stuff as needed.
Take pictures through the process. Itll help when it comes to putting it all back together.
And label your nuts bolts/// i didnt and its still a mess.
Ok so I didn't use the happy hooker, I have a slight problem with using it as I have a fuel rail bolt broke off, the front driver one. Guess what? Its also broke off on the motor I'm putting in also! Anyone have any advice on getting it out?
Ok so pictures below, I pulled the intake manifold off, doesn't look like I can get the hoist in far enough though? I had a chain hooked into I would guess if looking at the book would be holes 1 and 4 in the tightening sequence. Anycase one on each side. When I try to lift the motor it pulls the hoist into the nose instead of trying to get the engine up. I think I got the block separated far enough from the trans, how should that all look? 1st engine pull here, need some advice.
