Motor out the top
I took out even the A/C condenser so I guess I have room that way, but before I try to pull the motor out, would like to know everything else. To add more fun this is the first motor I've ever pulled.
Cars a M6 if it makes any difference, I have the wire harness disconnected and off to the side, haven't figured out if its best to separate the A/C compressor from the motor and leave the lines hooked up, or leave it on and unhook the hard line to the back, there wasn't any refrigerant in it anyway.
If you want more help just PM me. I'd be glad to help.
Not looking at taking the heads and intake off either. Just looking for advice on pulling it out the top. How many bolts are there from the trans to the motor? I've been told 6, I'm guessing two of the bolts are near the top that I can't see?
I took out the 6 bolts from the motor mounts to the block. Looks like I got all the wiring out of the way, grounds, etc. Mostly wondering about the PS steering pump also now. Is there enough room to take it off the bracket and pull the motor?
I think I'd probably take the hood off I guess.
I just came back in and it seems like getting the motor disconnected from the bellhousing is going to be a complete bitch.
Does the car need a alignment after doing it this way? Besides the 6 obvious bolts holding the kmember, the strut bolts, and the trans crossmember, anything else need to be undone??
Should I pull the sway bar completely off, or just unhook it from the mounts and leave it hooked up to the a-arms?
www.ls1videohowto.com
https://ls1tech.com/forums/lt1-lt4-modifications/935163-motor-r-r-video.html
I'm def. going to bookmark your link though, when this new motor goes someday, a LSx is going in its place, and I'd probably go through the bottom next time. I'm close to being ready to take it out the top.
Fast- Do you recommend pulling the intake manifold for clearance or is there another reason? I suppose I don't mind pulling it to take this motor out, but as for putting the new motor in, I'd rather not remove the intake manifold and reinstall once in the car.
Wondering why, so please inform.
Thanks everyone so far. -Corey
Well I'll def. pull all the accessories as I need to swap them to the new motor anyway, can I keep all the accessory brackets on though? New motor has the brackets on it already.
So far seems people say pulling the intake def. has to happen, any more opinions on this?
Its raining all the time in FL now it seems and the car is outside, so no progress yesterday or today, probably none tommarow either.
