What is this ticking noise?
After some initial fiddling with the lash setting, set with the engine running and at full operating temp, I have the pre-load set at 1/8 turn, per the direct recommendation of the two different CompCams people I spoke with. I would think, hopefully, that the Comp tech people should know what's best for their products. In my particular application, "So far, so good"...
I can't really understand what the issue is...The rockers aren't ticking because I know how they sound when they do since I adjusted the valves with the motor running. They are squirting oil like they should so the lifters are working properly it seems. Good thought on the manifold, but I know that thing isn't leaking because I dropped it straight onto a thick bead of RTV and torqued it in sequence. Pretty puzzled still, I may just tear it back down stick new lifters in and go from there. I leave in 2 weeks so it wont be until xmas that this POS gets done! I am so mad right now I have already punched a hole in the wall and broken a drawer within the last week
I went back to the original vid and gave it another listen....boy that tappin' is NASTY! Almost sounded way too loud for just loose lifters, more metal to metal....Given that you checked all the really obvious stuff at least 2-3 times, and the lifters SHOULD be OK, since they weren't noisy right up to the time you re-fired the engine for the first time.....
Is there a chance that A) you have a valve spring coil bind issue; B) a mechanical clearence issue, such as the underside of the retainers colliding with the oil seals; or C) your new valve springs are too stiff for the hydraulic lifters, so they're not really pumping up correctly?
Just something to ponder for the next few weeks..... Too bad you have to put this project on the back burner for so long.
I will probaly grab some LS7's or I may just get the Comp R's assuming Comp has fixed whatever issues they had with them. You seemed to be fine with them so I may give them a shot since they practically have a set place to set preload at.
In fact, that was part of my reasoning for putting new springs in the motor....It sits quite a bit with the valve/springs/lifters in one position for extended periods. I don't know what the long term effects of that are. I do start the car every couple of weeks during the winter to warm it up, and circulate the oil, but still, it sits for a time.
BTW 95Hawk467: Where exactly do you live? I live in south eastern PA right below Quakertown but have family up in the Montrose area which I assume is up your way?
I talked to Bret Bauer the other day and he said that its simply how loud those particular rockers are and swapping to LT4 valve covers or some billet ones would quiet it down. He reasoning is that the stock LT1 covers were designed for use with stamped steel rockers where as say the LT4's were designed for use with roller rockers and they are known to keep the noise inside. Makes sense to me so that looks like the next resort.
I could be wrong though, some rockers are louder than others.... Be sure to post back with an update when you get those LT4s on there, I'm interested to see how it turns out.
