Cams!!
Old Jul 28, 2008 | 06:45 PM
ROWDYZ28's Avatar
Default Cams!!
Hey all, I just bought another LT1 (94) and wondering if the Hot Cam is still avail? I herd not to long ago that they stopped making it...true. If not I want to throw one on the new ride.
Old Jul 28, 2008 | 07:08 PM
StealthFormula's Avatar
Here you go:
http://store.summitracing.com/partde...t=nal-24502586
Old Jul 28, 2008 | 07:23 PM
ROWDYZ28's Avatar
Originally Posted by StealthFormula
You seem pretty up to date with stuff. Question, if you wanted to build a low end torque monster would you pick either the hot cam or say the crane 227? Or does something else come to mind. Needs to be sniff approved..
Old Jul 28, 2008 | 08:05 PM
BigZee71's Avatar
I Just installed a hotcam kit. Just got it fired up today. It will pass the sniffer with a tune, maybe with out a tune. I bought it for steetability and that you dont have to run a stall. Im hoping to see 325 335ish Rwhp.
I bought my kit from someone on Cz28.com who bought it and never installed it. Picked it up for 350 bucks NIB.
Old Jul 28, 2008 | 08:09 PM
ROWDYZ28's Avatar
um they are 209 bucks on summit..looks as if whom ever sold u it hosed ya
Old Jul 28, 2008 | 09:22 PM
OreoLt1's Avatar
He may have meant a cam install kit w/cam
Old Jul 28, 2008 | 11:11 PM
Personally in that case I would go 227 because the torque will come in sooner and greater. Both will have good torque but the 227 is more known to be a torque monster. Both will pass emissions no problem. Another one to consider would be the LPE 211/219, which will act similar to the Crane.
Old Jul 28, 2008 | 11:13 PM
slagger's Avatar
how would the 227 be with 11.3-1 CR and a 3.42 gears and 2800-3000 stall?
Old Jul 28, 2008 | 11:51 PM
thats a good stall size and gear ratio for that cam.
Old Jul 29, 2008 | 06:56 PM
NightTrain66's Avatar
LS1TECH Sponsor
Crane 227 (210/224 114 LSA) will still work great as long as you want to shift around 5900-6000 RPM or so.
if you wanna shift at a higher RPM, there are better catalog cams and a custom cam can improve even more over them.
The CC 503 (224/230 112 LSA) is a good choice for still passing emissions and work with that gear/stall. It will pull to 6200 RPM or so.
Others will work for you but these are the most common catalog cams that will pass emissions.
Lloyd
Old Jul 29, 2008 | 09:46 PM
supernaturalta's Avatar
Do a search for "Cadillac cam". SpeedInc sells it.
Old Jul 30, 2008 | 12:14 AM
Elliott's94Z's Avatar
Lloyd
I think you are thinking he is doing this to the set up he has listed in his signature.. Rowdy, this is a bone stock LT1 you are wanting to change the cam shaft out in right?? From your first post you put up it looks that way..
Old Jul 30, 2008 | 03:55 AM
LS1TECH Sponsor
yep, I was assuming it was going in that car but the info is still good towards a stock LT1 F body as well.
Lloyd
Old Jul 30, 2008 | 09:13 AM
yep, I was adduming it was going in that car but the info is still good towards a stock LT1 F body as well.
Lloyd
That cam seems like a little to much for a stock LT1..I have heard of a few guys having problems passing smog with the 503..I don't see this cam beeing a good choice with stock heads and no headers or other bolt-ons to go with it. Just my 2 cents...
Old Jul 30, 2008 | 09:23 AM
LS1TECH Sponsor
If they are still wanting to shift at 6200 RPM, they are gonna need a cam like this or even larger. It is fine with a 6 speed and an A4 will be better off with a stall but the "right" cam choice is about how much low end power the customer is willing to scarifice and how high he is willing to shift at.
This cam is mild enough to pass emisions easily unless the tune is off or other problems are presnt (dirty MAF, leaks in elbow between TB and MAF, exhaust leaks, clogged inj, bad o2's, etc, etc).
Lloyd
Old Jul 30, 2008 | 09:30 AM
Lloyd
I think he should look into getting some bolt ons put on before putting a cam like the 503 on..needs to take off them stock manifolds to help it flow better
Old Jul 30, 2008 | 09:35 AM
LS1TECH Sponsor
1 3/4 headers and CAI should be FIRST on any build up . . . way before a cam swap. I was just following the theme of the thread towards cam selection.
I would do a good Yank/Vigilante stall converter (if A4) and exhaust system before a cam as well if it were me.
Lloyd
Old Jul 30, 2008 | 09:44 AM
Lloyd
x2...I agree
