LT1 internals???
Old Aug 3, 2008 | 09:38 PM
firehawk238's Avatar
Default LT1 internals???
what is the difference between the LT1 crank and the crank of any other one piece rear main 350? also is there more limitations to stroking on an LT1. id like to try and pull 427 cubes out of mine. is that possible?? am also planning on going to the GM847 cam. any ideas?
thanks in advance
karl
Old Aug 3, 2008 | 09:59 PM
IronOutlaw's Avatar
correct me if im wrong someone, but i think the bottem end of an lt1 is the same as a 1 piece rear main 350 smallblock. Ive seen a lot of guys go 383 and 396 but im not sure if you can go 427.
Old Aug 3, 2008 | 11:47 PM
YodiBrodi's Avatar
right about the crank, it is a plain-jane late model small block crank. you will not get 427 cubes from a LT1. nowhere near enough material in the block to cover the bore or stroke of a small block that size. cam is too low as well
Old Aug 4, 2008 | 05:47 PM
96capricemgr's Avatar
Build is destined for failure since you are focused on maximm cubes and a mediocre off the shelf cam and never even thought to mention heads. In otherwords you are focusing on everything but the one thing that matters most. If you follow through bet someone with a 355 teaches you a hard leason about what you should have done different.
Old Aug 4, 2008 | 05:55 PM
well perhaps you should have asked about my current mods, and even more so about my current heads. seeing as my heads were hand build by MTI and are stage 2 valves with stage 3 porting, im pretty sure they will hold up just fine. but thank you for your negative concerns. and if you have that 355, then by all means, lets dance....
Old Aug 4, 2008 | 06:34 PM
Thing is a 350 vs. a 427 may not want the same heads?? so even if they are working wonderfully now, they may not on a 427.
Still sporting a GM 350 shortblock.
Old Aug 4, 2008 | 07:41 PM
well the guy who owned the car before me had the heads done up to support a big cube stroker cause that was in his future plans.
Old Aug 4, 2008 | 07:46 PM
lt1noob's Avatar
why do you have to be so negative about **** dude...and its not exactly mediocre for an off the shelf cam.
Old Aug 4, 2008 | 07:50 PM
fastburn's Avatar
stage 1 stage 2 stage 3 stage 4 stage 5 stage 6
ive always hated the term "stage" blablabla.
it makes absolutely no sense.
stage 1 ***
stage 2 face
sage 3 ****.
no details just illiterate lingo.
what is stage 3 porting and what are stage 2 valves?i guess im lost ...
Old Aug 4, 2008 | 08:31 PM
well had you not made a pathetic attempt to insult me and use a word that is gramatically above your level (illiterate) then id give you the specs, but for now ill remain as illiterate as you are incompetant and bid you good day mouth.
sincerely
karl
Old Aug 5, 2008 | 07:28 AM
fastburn's Avatar
what stage mouth? lol
