nobody can answer this is thur some1
Old Aug 9, 2008 | 12:18 PM
robsquikz28's Avatar
Default nobody can answer this is thur some1
well basically i have dropped 100 lbs yes a hundo off the front end either way now my front end sits higher as expected.
now i have 1.56 short times with this suspension setup can i put a 1" drop spring on there to compensate for looks but still run that short time.
or do a need a adjustable shock as well to have as a 50-50 then adjust to say a 90-10 shock with the 1" drop.
wondering if any1 on here has encountered this before or have any suggestions to what works and what will not.
Old Aug 9, 2008 | 01:10 PM
LM97Z's Avatar
Never hurts to have a 90/10 shock up front for drag racing, i think you can lower it back down & still do good with an adj. shock.
Old Aug 9, 2008 | 07:35 PM
yea but the thing is with the 1" lowering spring and the 90/10 shock will it still benefit from weight transfer as if it already a stock type spring and shock
Old Aug 9, 2008 | 08:53 PM
BOLO's Avatar
QA1 RC7855P(front adj. shocks) and 15FB275(front springs). You can adj. the height aswell.
