Best Bang For The Buck Questions
Old 08-11-2008 | 07:48 AM
LT1Neumann's Avatar
Default Best Bang For The Buck Questions
Just got a 1995 Z28 Camaro, 6 speed!
I've been trying to read up as much as I can about it but, I can't find what I'm looking for.
I'm looking parts that gives me for the best bang for the buck on a LT1. If someone could give me a run down on the first 5 or so parts I should look into and install that would be great, thanks in advance.
Old 08-11-2008 | 07:55 AM
96capricemgr's Avatar
You looking for feel and fun on the street or for track performance??
In no particular order
Gears, need tuning to correct speedo so maybe save this for last, tuning is surprisingly cheap and easy though.
headers
catback
cai
tuneup, not typically thought of as a performance thing but let's be realistic, it's a 13yo car this is a good place to start.
Old 08-11-2008 | 08:21 AM
LT1Neumann's Avatar
A mix of both
Old 08-11-2008 | 08:30 AM
moehorsepower's Avatar
Anything you do will need (benefit) from a tune, even in stock trim a tune really helps, Gears are the best for a M6, go with 4.10's, RPM's will still be very reasonable in 6th on the highway...Opening up the intake and exhaust is a must on the LT's...
Old 08-11-2008 | 09:47 AM
96lt1m6's Avatar
drag radials
throttle body by-pass
up to date tune up!!!!!!!!!!!
cai,160*stat,t-b by-pass
mac mids or longtubes
elec.h2o pump
1.6 rockers,new valve springs
255 fuel pump,new injectors
4.10s m6 or 3.73s a4
tune,tune,tune................
i realize you said (5) but each mod compliments the next..if you plan on a 1500.00 budget expect to pay 2000.00
OR
drag radials
cai,t-b by-pass
255 pump,new inj.
mids or long tubes
100-150 shot
theres 5 you can get away with and still have a bunch of fun
Old 08-11-2008 | 09:52 AM
Elliott's94Z's Avatar
4.10's, LT's, cold air, exhaust and a tune
If you do gears I would swap the stock driveshaft to an alluminum LS1 dirveshaft.
Old 08-11-2008 | 10:26 AM
IMO the electric WPs are overdone for street use. yes they put more power to the wheels, but they also suddenly and completely fail as opposed to the slow weeping of the mechanical pump. Don't catch it in time and your motor will overheat and ruin parts FAST.
Many of the smrter guys that use them and understand things actually notice HIGHER water tems at cruise.
Old 08-11-2008 | 02:34 PM
97Z28LT1's Avatar
Agreed, there's no way I'd put one of those on a DD anyway.
I'd do all the maintenance first off, then:
CAI
Long Tubes & Exhaust (If emissions testing do what you can get away with)
4.10s
Shifter (Much funner to drive with a shifter IMO. The stocker is a long throw)
Drag radials
Tune
Keep an eye out on that clutch, too. Don't want to spend a bunch of money on go-fast parts and then the clutch goes out when you're broke. I've seen a few people buy these cars from people who don't have a clue and the clutch is shot.
If your luck is like mine, the clutch will be shot and the 3-4 shift fork will be bent. That's how my car was when I got it, but I pulled it out of a salvage yard so I couldn't test drive it.
Old 08-11-2008 | 04:13 PM
LT1Neumann's Avatar
Thanks for all the input guys. The car needs a new optispark first then I will do maintenance so the car can handle being run hard. Then down the list of go-fast parts
Old 08-11-2008 | 05:22 PM
I8ASaleen's Avatar
Is this a DD car? If not you could definitely stand some weight reduction. With an E-wp I would use a relayed warning system b/c you don't want it failing on you without prior notice. Like everyone else said CAI, tuneup (with some fatter plug wires), Headers, t-stat, manual fan switch, DR's, tb-bypass, these are all great places to start.
Old 08-11-2008 | 07:03 PM
Mr. Camaro's Avatar
For a six speed go with a short shifter 1st.
http://www.afterthoughtsauto.com/pro50towshif.html
then CAI, CatBack or cutout, and 4.10 gears
Edit: Forgot about the Skip Shift Eliminator
Old 08-11-2008 | 07:46 PM
hyperzone's Avatar
Check out the Newbie Sticky. Dont take offense, its actually got good info for anyone that is new to the LT1 stuff.
Old 08-11-2008 | 07:57 PM
Cheap Guy's Avatar
First of all, congrats on your moment. What color didya get?
Skip shift eliminator, CAI, catback, shocks, tires. It's a good balance between performance and handling. The stock shocks are really bad, in fact, if I had to do it over again, shocks would come before exhaust. The skip shift should be the FIRST thing you do, and it only cost about $12.
Skip Shift - $12.00
CAI - $100 (used)
Shocks - $400 to $1000 depending on what you choose
Catback - $350 (or $100 if you go muffler only)
Tires - Depends on what you want. A lot of people like Goodrich KDW's, which would run about $500 for a set
Old 08-11-2008 | 11:26 PM
LT1Neumann's Avatar
Green, black top. I posted pics in the media sticky. The previous owner had a catback installed.
Edit:
If I decide to get into autocross, what are the best bang for the buck parts for suspension/handling?
Old 08-11-2008 | 11:56 PM
Fixxer99TA's Avatar
Theres really no way to short cut and save money on the suspension, if your going to set it up to autox then your suspension setup is something your not going to want to skimp on.
Spohn, BMR, Hotchkiss ect... are all good companies to start looking at. Just do it right the first time and you wont have to spend more than you have to.
As for bang for the buck, I would think you would see most difference from a set of lower control arms, subframe connectors, torque arm (for hard accel.), strut tower brace, and maybe even lowering the car a little. Think about some bilstein shocks or something along those lines, and maybe some good tires to stay on the road . All of this will tighten the car up.
Old 08-12-2008 | 12:10 AM
LT1Neumann's Avatar
How is the brand UMI? Also are Koni's worth the price or are you paying for the name?
Old 08-12-2008 | 12:16 AM
Fixxer99TA's Avatar
I havent used Koni's or UMI, so others will have to comment on those.... If I remember the Koni's are adjustable so that would be a plus. Most of my suspension stuff is either BMR or Hotchkiss.
Old 08-12-2008 | 01:39 AM
StealthFormula's Avatar
UMI makes some amazing pieces IMO I've had great luck with their products and only run and will only ever run their suspension components on my car. I have only heard good about the Konis and wish I had the money to get a set. If you do some searching in the suspension forum you will see UMI is regarded as the best or one of and the Konis seem to be the "God" of shocks.
Old 08-12-2008 | 10:24 AM
AChotrod's Avatar
I would do a shifter, skip shift eliminator, CAI, cat-back, 160 stat., gears and tune. to start.
Old 08-12-2008 | 10:28 AM
UMI all the way
Quick Reply: Best Bang For The Buck Questions
