My T56 Conversion..
Old Feb 26, 2009 | 06:13 PM
  #61
ThoR294's Avatar
pfffffffffft shift light newb!
haha. I want a coverl ike that but with a WS6 on it!
Old Jun 28, 2009 | 10:57 PM
  #62
Stang-Slayer's Avatar
So that rev wire is the one u also need for reverse lockout also?
I got it with just reverse lights right now
Old Jan 18, 2010 | 01:32 PM
  #63
siguy's Avatar
nice write up
Old Jan 18, 2010 | 02:49 PM
  #64
the_merv's Avatar
Veteran: Air Force
Thanks.
Old Feb 8, 2010 | 09:17 AM
  #65
the_merv's Avatar
Veteran: Air Force
Updated and re-worded to make it a little easier to understand..
Old Feb 18, 2010 | 03:07 AM
  #66
JB_97ws6TA's Avatar
When you bypassed the CAGS did it kick any codes by not having the signal to the PCM? As I understand it you did not include any of the wiring in the harness so when to PCM was tuned for m6 there was an open pin on the PCM where the skip shift would have been. How did you alleviate any problems that this may have caused and is there any reason why you couldn't have just left the solenoid in place but not have it hooked up? Thanks
Old Feb 18, 2010 | 07:24 AM
  #67
the_merv's Avatar
Veteran: Air Force
I removed it totally cause why have it there if it's completely useless.
I had the CAGS tuned out of the PCM when I had the M6 Tune put in. I wouldn't have any lights come on anyways cause the Gauge Wiring for the Shift Light isn't there either..lol
Old Feb 18, 2010 | 01:42 PM
  #68
JB_97ws6TA's Avatar
what did you use to de-pin the PCM and also are the cruise control switches for the clutch and brake the same switch ie same part number?
Old Feb 18, 2010 | 02:09 PM
  #69
the_merv's Avatar
Veteran: Air Force
The PCM Connectors come apart..carefully take the colored plastic piece off and you can see the white Tabs that hold the Pins in. I popped up the Tabs and pulled the Pin out.
I don't know if the Switches are the same part number..I just moved the Cruise one over from the Brake to the Clutch and wired the TCC portion of the Brake Switch into it in Series circuit.
Since the TCC Function was no longer needed it was an extra switch..no sense of not using it.
I added a diagram to my first page..
Old Oct 17, 2010 | 05:47 PM
  #70
MLP00Z28's Avatar
I just did a t56 swap on my 00 Z28 as you, wired everything the way you did but the cruise switches, can I connect the TCC in series with the clutch cruise switch? What I want to know is if ls1 harness works the same as lt1 in this particular case?
thanks
Old Jun 26, 2012 | 01:08 PM
  #71
the_merv's Avatar
Veteran: Air Force
Yes, it has to be connected in series, but wired like I did it in the diagram. The TCC Wiring will have no purpose if swapped to a M6.
Old Jun 27, 2012 | 02:12 AM
  #72
LT1's Avatar
LT1
Late respons lol
But, good info in this thread. I might be using this info for a future project.
Does the slave cylinder need to be drilled in a certin spot or as long as its close enough?
Old Jun 27, 2012 | 02:27 AM
  #73
the_merv's Avatar
Veteran: Air Force
Yea it's been a min since I've been in here..lol..
You mean the Master Cyl..
There is a template on the rubber on the firewall, as long as its within 1/4" it should work.
Old Jun 27, 2012 | 02:35 AM
  #74
LT1's Avatar
LT1
Cool didn't know that ill check it out.
Old May 20, 2014 | 08:23 PM
  #75
twoolley08's Avatar
hey about the cruise control I have a 2000 trans am and this pic is how my wires are for the brakes and cruise switch on the auto side.
What do I do for this wiring?
or do I just take switch 25 and place it in the clutch spot and call it a day???? are any changes needed on the pcm wires for this to work? I know I saw it somewhere before but I can not find it now.
Old May 21, 2014 | 10:30 PM
  #76
SoxXpupPeT's Avatar
Bringing this one back from the Dead!
Old May 22, 2014 | 08:17 PM
  #77
twoolley08's Avatar
any input?
Old Jul 24, 2014 | 09:40 AM
  #78
the_merv's Avatar
Veteran: Air Force
Follow the diagram I made, wire it in with the one on the Brake Pedal.
Old Aug 1, 2014 | 07:24 AM
  #79
Hah glad to see this thread alive again I did this a few years back with the help of soome coaching by Merv. The only problem I ran into is that now my cruise control doesn't work. I have no idea how the swap changed that.
Old Jun 18, 2015 | 09:01 AM
  #80
Derekwhite's Avatar
Do. You. Have. Any pictures. How to do the neutral safety switch. For ls1 t56 conversion
