Thinking it may be time for a "Tune".
Your car is already quick for the mods done Get a TB instead, then a cam and head work then a dyno tune.
Bryan Herter (at PCM4less) did my tuning for my current setup, and I am sure that if I took it to a dyno tune, they wouldent pull too much more out of it. Bryan knows his stuff, and has gotten some setups I have seen within 5hp of a dyno tune..... So anything is possible.....
Yeah its getting down there in ETs, this old boat still has the jack/spare in it, i'm looking to grab another .2 out of it hopefully in the next 2 months, maybe i'll just hold off on the tune for now & get some SFCs instead, i did find my MAF was gummed up about 80% from the K&N oil, that alone was telling the PCM it was rich & leaned out the fuel signal (helpful hint from Brian to check this), now i had to lower back down the fuel pressure & the engine runs smoother, alot smoother & runs cooler too, but he did say the hypertech runs a 12.0 F/R @ wot, he likes to set them leaner then that.
But Since you dont have SFCs yet that would be my next move also.
With your basic set up plus a 52mm TB and Granatelli MAF with 3.73s, Jba shorties and stock y-pipe w cats my old 97 was trapping 104-105 all day 107with a hotcam kit b4 tune and 111mph after Ed wright tuning. 120+ on the juice. I miss that car!!
But for the $$$ is a 52cc TB worth the upgrade? Because to honestly tell ya, it'll most likely never get a cam/head up-grade while i own it, just can't afford it, so what would be more justafiable for the $$$, a mail order tune or a 52cc TB?? The SFCs are a must, so thats what i am getting next, after that, i'll just work on getting the 60fts. down for the best ET, by fall if i can run down a 13.2 pass with this car at its full weight & 158K miles, i'de say i'm doing damn good, wouldn't you
Your car is pulling some good ETs for sure. 13.2s are in the future.
