Mustang owner coming over to the LTx side
This weekend I am going to be picking up a bone stock 94 A4 Z28 with 100k on the ticker. It's overall a very clean car and even after going over the car with a buddy of mine that owns a speedshop we both agreed the car really looks like it has closer to half the mileage.
Anyways, I am selling an 03 Cobra swapped GT due to expense reasons and I found a great deal on the LT1 car. Coming from a car that ran high 11's and trapped low 120's this new car is going to feel dead nuts slow to me, but I plan to change a few things right off the bat. I won't have a ton to spend, but I'm thinking of something in the neighborhood of 1500-2000 dollars right away.
After doing some research I've decided on cam only, exhaust, stall, and suspension pieces. I plan on doing all the labor myself so I don't need to factor in any of the labor other than a couple hours where I'm going to have my local speedshop dial in the suspension. I just want something that is going to give me a very streetable car while shooting for around 340-350rwhp through a loose stall and a big tire.
Cam-wise I was thinking either a CC306 or a CC503 cam. I thought the 306 might be too big, though, for stock inch and stock heads, but on some of the videos I've seen it looks like other guys have done it. They both seem to have the same centerline too, which gives them both a really nice sound. I want a cam also, that's going to give me room to put a bigger head on later, but still perform well now. With that in mind, some LE heads and AFR 210's are available locally at a shop. What are the current market value for these heads. He wants 1300 dollars for the LE heads and 1500 dollars for the AFR's, it sounds expensive, but I really don't know what they are actually worth.
As for the exhaust, the car comes already with a Randomtech catback and I was going to do midlengths, but looking after looking at the FAQ it looks like the rule of thumb is "go LTs or go home". Pacesetters look to be the cheapest brand, but is there a more expensive brand that is better? Or are all LT's going to be the same?
I was also going to do a 3800 YANK stall since I figured it would work well with a bigger cam like the CC306 or the CC503, but I'm not sure if it would be very streetable. This is also my first auto car, so I don't know what a stalled auto drives like. Keep in mind as well that this car already has 3.73's.
As far as rear end components I was thinking BMR adjustable torque arm and lower control arms with relocation brackets for easy IC dial-in and launching characteristics. This is what another guy I know uses on his 'Bird and he cuts 1.6x's on MH Drag radials. Chime in if you think there's something I'm missing. I've heard panhard bars help, but I wasn't too sure.
I think this is all the questions I had. Thanks for any advice in advance.
Chris
The heads you mentioned sould like a good deal too! Those AFR's should be real nice as should the Lloyd Elliot heads assuming they really are from Lloyd. The LE heads could be his version 1, 2, or 3 so keep that in mind also.
Cam wise you'll see just as good results w/ the 305 as the 306 w/ stock heads. Now you mentioned wanting a cam that will allow you to throw some better heads on later then I would just go ahead with the 306 now so you don't have to fiddle with it later
For suspension you pretty much got it down. I would also throw in some subframe connectors. It wont help your launch but it will tighten the car up.
I would say to get a matched head and cam package from LE or AI and go from there, but that will stretch a budget build very quickly. To run 11's NA with an auto you do not need a huge cam but you DO need a nice stall and suspension work. With an LT1 your ET will be all in the 60', not the top end.
The little things add up like crazy, and unfortunatly 1500-2k wont get you very far with an LT1 compared to a supercharged engine. Once you get into the big mods though "all gloves are off" and the sky is the limit.
Like stated, it sounds like you did more research then most people who snag fbods.
Welcome to the club
. Trending Topics
This is all from Texas Speed other than the LPP exhaust.
LPP LT's & Y-pipe - 550
UMI Tubular LCA's with spherical ends - 179.99
UMI Body Mount torque arm with LT clearancing - 389.99
UMI bolt-in LCA relocation brackets - 89.95
The exhaust is the most expensive of the group by far, but I've heard with the LT1's that they offer significant gains versus a 2v Mod motor or even a 4v Mod motor. The suspension is just something I wouldn't be comfortable buying second hand no matter what and this leaves me with I guess my final decision. It seems to me that I am not really going to fall within my budget restraints at this point.
The cam itself they offer for 233.99 but if I figure in things I should probably do at the same time anyways (rockers, pushrods, springs) I'm looking at closer to 700 dollars (mainly because of the rockers). What is absolutely necessary when going to a CC503 cam? Springs only? Pushrods+springs? If I didn't have to do the rockers with the cam install I wouldn't be beyond my budget, but the CCMagnum rockers are 280 bucks!
Another alternative I'm thinking of is running a nitrous kit instead. Used kits are dime a dozen locally, but I'm open to any and all suggestions of what I should do.
To me it sounds like you would be better off buying a used N2O setup with all the goodies and the suspension and converter should net you what you're looking for. With that I'd buy a Walbro pump, and maybe even a good set of SVO injectors to be on the safe side for nitrous.
So far I suppose then I have longtubes, suspension, and a stall which I hope will net me a 13.x @ 104-106 and then I'll have to decide later whether I juice the car or I go with the cam.
Thanks again for the helpful replies and I'll try to get pictures up ASAP.
550 for headers and ory
not sure which catback you want...lets say you get the rumbler which is 250...not a personal preference but if your on a budget
LCA 180
Relocation brackets 65
Torque Arm 390
Stall 725
which brings your total to 2160 which is just over your budget but will get you a pretty stout car...now if you plan on camming it in the future plan on doubling what you think itll cost because usually people leave out all the small stuff that adds up like gaskets, studs, etc
Also, what was your best recorded ET?
