high compression LT1 guys
Old Aug 23, 2008 | 08:04 AM
  #41
Puck's Avatar
Originally Posted by OutlawZ
yeah.... +1....
you guys with avgas and 2 stroke oil are begging to blow your motors up.....
If you're that unsure of what fuel to use just pour 1 ounce of chuck norris' urine into a full tank of gas.....
effectively raises the octane to somewhere in the 300's...... LOL
Old Aug 23, 2008 | 10:34 AM
  #42
Fixxer99TA's Avatar
The octane level of Chuck Norris's **** cant be chemically measured, dident you know that..?
EDIT : Not only that, but where the hell are you going to find a container up to the task of HOLDING that while you pour it?
Old Aug 23, 2008 | 10:40 AM
  #43
Stefan D.'s Avatar
My old 401 LT1 was 13:8 to 1, used a TCI mini with no issues.
Old Aug 23, 2008 | 01:34 PM
  #44
meangreenformula's Avatar
Sorry if this is a newb question but, what kinds of things are you guys doing to run a higher compression ratio?
Old Aug 24, 2008 | 10:43 AM
  #45
Dave J's Avatar
this is what has been happening to the stock starters
http://www.flickr.com/photos/1551097...06855/sizes/l/
Old Aug 24, 2008 | 11:53 AM
  #46
FASTFATBOY's Avatar
Dave that is USUALLY cause by an alignment issue and or "kickback"
Old Aug 24, 2008 | 12:54 PM
  #47
Dave J's Avatar
ya its hard to see that kinda thing with no hoist only jackstands I guess I will take more time to try and eye it up and see if I need a small shim or something in there
I also forgot to mention I have a digital 7 msd box and I retard the timing on startup by 15 degrees or whatever the max is
Old Aug 24, 2008 | 04:43 PM
  #48
strokedz383's Avatar
Well my starter just died. Only have 12-1 comp, but it was the stock starter. Only fired this motor about 30 times or so. I think I'm going to get a powermaster.
Old Aug 25, 2008 | 12:20 AM
  #49
Dave J's Avatar
thats about what I got on the last one 30-40 starts
Old Aug 25, 2008 | 05:44 AM
  #50
Greaseymec's Avatar
...using pistons designed for a particular CR, block decking contributes some as well as head gasket choice. Combustion chamber volume is also figured in, in regards to what you are trying to do with the motor, etc.....
Mec
Old Sep 28, 2008 | 11:14 AM
  #51
flyinZ's Avatar
Dave, what did you end up using?
I dont remember what tooth flywheel I have..anybody know off hand? Just an M6, McLeod ST,steel flywheel.
Old Sep 28, 2008 | 11:47 AM
  #52
Vendetta's Avatar
Holy crap @ 13.7:1
Old Sep 28, 2008 | 12:00 PM
  #53
TwoFast4Lv's Avatar
It should be a 153 tooth
Old Sep 28, 2008 | 12:22 PM
  #54
Dave J's Avatar
I tried a powermaster but is wont clear the kook headers.So I bought a stock vette one and I am going to get a second as backup
Old Sep 28, 2008 | 03:02 PM
  #55
flyinZ's Avatar
thank ya.
Ellis,did ya get my PM?
Old Sep 28, 2008 | 08:43 PM
  #56
TwoFast4Lv's Avatar
I will go look
Old Sep 28, 2008 | 09:55 PM
  #57
1badzee's Avatar
11.5:1 compression with stock 93 starter (=
Old Sep 29, 2008 | 11:25 AM
  #58
1bad lad's Avatar
running 12.7 with a stock starter......just good clean cable connections with an optima red top!!!!!!!
Old Jul 9, 2015 | 04:27 PM
  #59
LT4orbust's Avatar
Originally Posted by Revelation Z28
only use 1 ounce of jetA in a tank. my dad used to use it in his jeep, and it never had clogged injectors
It seems cranking is about the same in my 12 to 1 ..... due to more overlap in the performance cam???
I think you should get a prosthetic to hold your dogs smile ...scary more than funny!
Old Jul 9, 2015 | 05:38 PM
  #60
bufmatmuslepants's Avatar
Dude George bush was still president when the last person before you posted in this thread.
