high compression LT1 guys
Old Aug 18, 2008 | 11:23 PM
Dave J's Avatar
Default high compression LT1 guys
what are you using for starter motors.I just blew apart my 3rd stock one.compression is 13.7
Old Aug 18, 2008 | 11:51 PM
SVTJayhawk's Avatar
Wow, how long did that motor last you?
I'm still learning LTx stuff, so I'm in for good tech advice.
Old Aug 19, 2008 | 12:03 AM
Quick96ss's Avatar
I have 12.0 to 1 compression With a Powermaster XS Torque Starter. It works Great!
Old Aug 19, 2008 | 01:25 AM
slagger's Avatar
powermaster here torque master it will crank up to 18-1
it has a gear reduction like 4-1 something like that and it cranks fast..
Old Aug 19, 2008 | 07:10 AM
Greaseymec's Avatar
Still doing well with a stock starter on 12.3 cr. No problems with a good ground and a fresh battery. I broke a few starters a while back. I mean I BROKE them. Hit the switch and after about 1/2 a rev the starter nose cone would go "clang" on the driveway. Turned out the opti cap was cross firing and really screwing things up. No problems after that (till the opti itself took a dump on the trailer at the LTx Nationals).
Mec
Old Aug 19, 2008 | 07:29 AM
BlackScreaminMachine's Avatar
Internet Mechanic
w/ a 11.25 to 1 street comp, used CSR mini starter w/o issue.
Old Aug 19, 2008 | 07:58 AM
Tony Shepherd's Avatar
13.7:1 ?? Damn!
I am at 12.3:1 using an LT4 starter. Works fine. I am about to lower my CR to 11.5:1
Old Aug 19, 2008 | 08:46 AM
Greaseymec's Avatar
Originally Posted by Tony Shepherd
13.7:1 ?? Damn!
More Juce?
Mec
Old Aug 19, 2008 | 09:15 AM
Originally Posted by Greaseymec
More Juce?
Mec
Higher quench, slightly less compression, E85 (maybe), and more juice.
Old Aug 19, 2008 | 09:25 AM
Colin91Z's Avatar
11.8 : 1 here, stock starter, no problems.
Old Aug 19, 2008 | 10:03 AM
Dave J's Avatar
I will give the powermaster a shot thanks for the help guys
Old Aug 19, 2008 | 10:30 AM
slick1851's Avatar
Do you run on 100 or 110?
Old Aug 19, 2008 | 11:00 AM
Dave J's Avatar
112 unleaded
Old Aug 19, 2008 | 12:06 PM
TwoFast4Lv's Avatar
PowerMaster XS also 12.5 to 1 with perfect quench
Old Aug 19, 2008 | 12:28 PM
Fixxer99TA's Avatar
I am going to have to remember this, higher compression in the future. Good info here guys, looks like that PowerMaster XS is the way to go.
Old Aug 19, 2008 | 01:18 PM
Kmaroman's Avatar
my car's compression is stock as far as i know. My bro told me to make some real boost use aviation fuel but put 2 stroke oil in with it to, cause Aviation fuel has no additive's
Old Aug 19, 2008 | 01:22 PM
formulajunky's Avatar
lol wow 13.7 thats high. powermasters are good though
Old Aug 19, 2008 | 03:52 PM
Revelation Z28's Avatar
only use 1 ounce of jetA in a tank. my dad used to use it in his jeep, and it never had clogged injectors
Old Aug 19, 2008 | 07:04 PM
Greaseymec's Avatar
Jet A is not gonna help any. Its really just a high grade kerosine.
Be careful. Av gas is full of additives. Also, even the low lead stuff has WAY to much lead for O2 sensors and cats. 21 years in aviation. FWIW
Mec
Old Aug 19, 2008 | 09:24 PM
Puck's Avatar
Reverse flow cooling means our heads are cooled first, allowing LT1s to run a lot higher compression then standard engines without detonation.
My rebuild will be shooting for 12.5:1, and my stock shortblock ran close to 11.1:1 on pump gas.
The tune makes a world of difference as well.
