$150 .040 over shortblock. Should I?
He is selling it as a shortblock and not entire motor because it includes heads, but he said the heads were cut to use bigger springs and stock springs could not be used. He said some work to the heads has to be done for the springs to seat. Intake manifold, and distributor are not included since he was going to a single plane and a different distributor. He is only about 20 minutes from me. I see this as being a great advantage for me to build the motor with ported heads, manifold, and cam while the motor is sitting on an engine stand.
What would .040 make in size as far as CID? Should I jump on this deal? He said he is just getting out of the hobby, the reason he is selling it.
Thats a good deal either way!
jasper is a pretty good rebuilder,just remember that engine is NOT rebuilt for our use unless specified.....not saying you cannot use it that way!
.040 is not that bad,did they reman.with hyperutectic pistons or just cast replacement?
is the rebuild still under warranty?
its worth the 150.00
if it was me i would instal new bearings,oil pump and timing chain.......
96lt1m6, what do you mean not rebuilt for our use? Throw a good cam in and port the heads and its good, right?
Not sure about warranty, he is going to send me some pics tonight.
Part of the heads were cut out to use bigger springs, as you can see in the pictures. Would it be wise to reuse these heads or just port my current heads? I believe these are iron heads from a caprice right? Which will flow better?
Is there anything on this that you guys see as a FLAG or caution. If so let me know. Thanks
