finally going to do headers, which gaskets?
So far I have no leaks, my friend used the Pacesetter gaskets and has had to tighten the bolts a couple more times than me.
I went with the felpro gaskets. No leaks and i havent had to retighten the header bolts since i put them on.
. so fel pro it is, what else will i need. lts, ory, gaskets, stage 8 bolts, do i need 02 sims or bungs? if so what size should i get. anything else? The Best V8 Stories One Small Block at Time
I used the copper gaskets that came with my macs..they have been great with no leaks at all. DON'T USE THE GASKETS THAT COME WITH THE PACESETTERS THEY ARE GARBAGE CAN
i have had pretty good luck with these, i have blown out fel-pro's and stockers...
